smoking 292 - Ford Truck Enthusiasts Forums
smoking 292
Old 11-20-2011, 09:05 PM
RhondaBruce's Avatar
RhondaBruce RhondaBruce is offline
RhondaBruce is starting off with a positive reputation.
smoking 292
New y block owner here. The 292 i just purchased seems to run well but some smoke comes out of the oil filler and dipstick tube. Doesn't seem normal to me, is it?
Old 11-21-2011, 01:29 PM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Known as "Blow by" indicating that your rings are wearing/worn out depending on the severity. Some leakage past the rings is normal. Check to ensure your PCV system is working correctly if so equiped.
You didn't mention year?? I am assuming that it is a different truck than the '78 150 as 292's were not installed in trucks after '64?
Old 11-21-2011, 03:03 PM
The truck is a '64, i haven't updated my profile yet. I haven't ran the numbers on the engine yet and don't know if that motor came with it or not.
Old 11-21-2011, 03:24 PM
Cool, OK. If it is not smoking too bad, check to make sure the PCV setup is installed and in working order, then the smoke will be routed to the engine and burned.
Good luck and welcome to the Wonderful World Of Y's...
Old 11-21-2011, 05:35 PM
Trad15th Trad15th is offline
Trad15th is starting off with a positive reputation.
Remember the old days,....when almost everyone's car blew by just enough to let your nose know it was idling?
You could always tell who needed valve jobs and who needed rings just by following them in traffic for a few blocks!
Old 11-21-2011, 05:45 PM
So should i not be driving it? What's the chances of a thrown rod or something just as bad?
Old 11-21-2011, 06:02 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
If it has oil pressure, drive it. Blow by is not going to increase chances of throwing a rod. If it is an original 64 engine it should have a pcv system. If it is an earlier engine it may have a road draft. Make sure the crankcase ventilation system, either kind, is clean and working right. A couple oil changes may help.
Old 03-30-2013, 10:48 PM
Jim Fleckenstein Jim Fleckenstein is offline
Jim Fleckenstein is starting off with a positive reputation.
new to the forum and the Y block motor. I just purchased a 61 Galaxie wth a 292 motor. I've done alot of research on the issue i'm having with smoke coming from the D/S rear of the valley pan. I've learned alot but haven't got a fix for it yet. The valley pan has a hole with what looks like a threaded boss inside it. I'm told that this motor had a road tube but that an adapter is available to cover that hole and will accomadate a PCV valve. Any insite would be appreciated
Smoke question jmtbiggin Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 4 06-02-2015 12:25 PM
more engine problem for my 292 tyfly's64 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-27-2010 09:09 PM
Smoking from oil fill cap and dipstick tube arwford 1961 - 1966 F-100 & Larger F-Series Trucks 8 08-23-2010 07:39 AM
292 390 engine swap spivey1 1961 - 1966 F-100 & Larger F-Series Trucks 2 12-24-2008 09:52 AM
292 running propane? 21411 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 6 11-21-2008 08:33 PM
Tags
292, block, degrease, engine, ford, forums, list, smoking, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
