Ball Joints
Old 11-23-2011, 07:44 PM
86sixbanger's Avatar
86sixbanger
86sixbanger is offline
Ball Joints
Wondering if I can change the balljoints on a D50 TTB without removing the rotor/hub assemblys, or is it more trouble than it's worth?
Old 11-23-2011, 07:54 PM
bashby's Avatar
bashby
bashby is offline
gotta remove hub, caliper, rotor, spindle, axle, then the knuckle. Then you remove the BJ's and press the new ones in. Do a search, there are step by step threads with pics. Maybe someone will provide a link.
Old 11-23-2011, 08:21 PM
Edgethis's Avatar
Edgethis
Edgethis is online now
Its not an easy job. especially if you haven't ever had to pull the spindles before, they will be nice and rusted to the knuckle.
Old 11-23-2011, 08:38 PM
86sixbanger
I know, which is why I was wondering if I could avoid all that. What's stopping me from popping the knuckle apart with the rotating assembly still on??? thanks btw
Old 11-23-2011, 08:57 PM
Edgethis's Avatar
Edgethis
Won't be able to get the nut off the lower ball joint, even if you managed that, you couldn't drop the knuckle low enough with the half shaft in still.
Old 11-23-2011, 11:52 PM
86sixbanger
But if you undid the snapring inside the hub, wouldn't the half shaft slide right out?
Old 11-23-2011, 11:54 PM
blkF250HD's Avatar
blkF250HD
blkF250HD is offline
I'm bracing myself for this task as well, although mine have been replaced in the past. Someone did an excellent write up with pictures at one point, however I've been unable to find it.
Old 11-24-2011, 12:50 AM
Edgethis's Avatar
Edgethis
NO.
Once you pull the hub and rotor:
http://www.flickr.com/photos/62639173@N03/6224173081/http://www.flickr.com/photos/62639173@N03/6224173081/ by http://www.flickr.com/people/62639173@N03/, on Flickr
HARDEST PART! Getting the old Spindle off:
http://www.flickr.com/photos/62639173@N03/6218856621/http://www.flickr.com/photos/62639173@N03/6218856621/ by http://www.flickr.com/people/62639173@N03/, on Flickr
As you can see, this is a D44, but very similar to the D50. You Literally have to tear the whole axle half apart.
Old 11-24-2011, 12:52 AM
Edgethis's Avatar
Edgethis
Here's a picture without the knuckle also:
http://www.flickr.com/photos/62639173@N03/6221991496/http://www.flickr.com/photos/62639173@N03/6221991496/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Once you have the knuckle seperate, then you need a press to get the balljoints in/out. This is a very labor intensive job.
http://www.flickr.com/photos/62639173@N03/6196420272/http://www.flickr.com/photos/62639173@N03/6196420272/ by http://www.flickr.com/people/62639173@N03/, on Flickr
Old 11-24-2011, 01:29 AM
Rebuild101's Avatar
Rebuild101
Rebuild101 is offline
He said it all in the pics can't be done other wise
lbrauer
1999 to 2016 Super Duty
04-02-2016 01:46 AM
riggers
02-25-2012 08:46 AM
ohmar99
03-21-2010 05:15 AM
Trolex409
1997-2006 Expedition & Navigator
03-05-2009 03:01 PM
79f3504x4
03-01-2002 03:05 PM
Quick Reply: Ball Joints
