Heater hose removal - Ford Truck Enthusiasts Forums
Heater hose removal
Old 11-20-2011, 10:27 AM
victorcharlie victorcharlie is offline
victorcharlie is starting off with a positive reputation.
Heater hose removal
My truck has ford heater hoses with some sort of fitting on the heater core end.
How in the world are these removed?
99 f-350, 7.3....Any advice appreciated.
Old 11-20-2011, 01:44 PM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
Maybe this will help.
Old 11-20-2011, 03:46 PM
Thanks!
I've bought gates hoses without the fitting. Can the fitting be reused on the gates hoses or do I put the new gates hose on with hose clamps?
Old 11-20-2011, 05:54 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
I spend about 2 hr trying to disconnect those "fast connectors" and finally cut them off.
Than since the system has no valve and keeps the heater core under the dash hot even with 120F outside, I added hoses to the heater core and make new junction with 2 valves in easy accessible place under the hood. Next time I have a problem with heater core, I can just shut it off and than at convenient time have conveniently accessible connectors to deal with.
Did I mention that turning off the heater core makes the cabin colder while on 120F desert?
Bottom line -cut off aluminum pipes to the core under your dash, pull the ends under the hood and deal with it where you can see what you are doing.
Old 11-20-2011, 09:59 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 1999 - 2003 7.3L Power Stroke Diesel forum.
Old 11-21-2011, 04:31 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
I went through this about 3 years ago, what a true PIA.
The replacement hoses (from Gates) DO NOT have the core end fittings (THANK GOD)
I first thought I'd gotten the wrong hoses but my parts jobber double checked and found that the ones with the special fittings were only used on the assembly line to save time, the new Gates hoses just slide onto the core fittings and then use a band clamp on them-I saved my old hoses (all of them) for spares-I just cut the heater hoses off right at the stupid factory fittings at the core end.
bad heater core, bypass or cap off? SteeIhead 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 3 10-16-2015 05:08 PM
Heater Core Hose Diameter Suprawill1 Escape & Escape Hybrid 5 01-23-2014 01:32 PM
how do u remove heater core hoses on 97 expy johnnkara 1997-2006 Expedition & Navigator 1 02-10-2009 07:15 AM
heater core hose removal??? zed326 1997-2006 Expedition & Navigator 3 01-28-2009 05:14 PM
how to remove heater hoses sidwaz 1999 - 2003 7.3L Power Stroke Diesel 1 01-20-2009 11:03 PM
Tags
1978, 30, 351, 99, bronco, duratec, expedition, fitting, ford, heater, hose, hoses, modified, pressed, remocal, removal, remove
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
