2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2008 left/rear thump, at a loss.
Old 11-15-2011, 01:05 PM
ibyers's Avatar
ibyers
ibyers is offline
Hey Guys,
I have a weird “thumping” noise coming from the rear drivers side wheel area.
It does it only when I hit a bump and seems to do it more when I am slowing down/breaking. The very odd time it goes from a loud single bump to almost a vibration. I have only heard it do this once, but my wife said it has done it a couple of times. The vibration only seems to do it while braking over a large bump, but again it is rare.
It sounds more like it is coming from the inside than the outside. I took the wheel off and checked suspension. I thought it might have been a loose shock mount, but everything is tight. I had my wife drive while I sat in the back, and it is almost like it is coming from the inside, but I have no idea what it could be. I might have thought it was the sub with a loose connection (is it in this area?) causing it to “thump”. When I had the tire off it appears the brakes are new (new pad and rotors)
It is not the access panel to the jack or the jack itself, as I removed them and it still did it. I also tighten the spare tire as I thought that might have been bouncing.
I’m at a loss.
Thanks everyone!
Old 11-15-2011, 01:17 PM
kennisonxgs's Avatar
kennisonxgs
kennisonxgs is offline
It could be the traction control. Mine does it mostly when turning over a bump at slow speed.
Old 11-15-2011, 01:33 PM
ibyers's Avatar
ibyers
ibyers is offline
good call, never thought about that.
Now is this a normal sound? lol
Old 11-15-2011, 01:58 PM
ibyers's Avatar
ibyers
ibyers is offline
The Thump is pretty loud. you can hear it over the radio.
Old 11-16-2011, 12:49 AM
kennisonxgs
Mine is loud enough. Whether or not it's normal--I'm not sure, but mine has been great so far. I don't know how loud your radio was at the time, so I can't comment on that.
Old 11-16-2011, 05:33 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Just curious do both you guys have the rear air suspension?
Matt
Old 11-17-2011, 01:20 AM
kennisonxgs
No, no air suspension
Old 11-17-2011, 10:50 AM
function12's Avatar
function12
function12 is offline
Did you check the spare tire? Might be loose.
Had that happen on a truck once. I felt real stupid after checking everything but that for the issue.
Old 11-18-2011, 11:52 PM
ibyers's Avatar
ibyers
ibyers is offline
Hi Function,
I did check the spare tire. Unfortunately it did not solve it.
Old 11-18-2011, 11:53 PM
ibyers's Avatar
ibyers
ibyers is offline
Matt
Hi Matt, No air suspension.
Old 11-18-2011, 11:56 PM
ibyers's Avatar
ibyers
ibyers is offline
Radio was not really that loud. can still have a convo with the passenger.
as I was pooking around tonight trying to find the source, my son slammed the passenger door and I heard the thump in the rear. So I am leaning away from suspension. the more I think about it the more I am thinking sub with a short.
Is the sub in the rear drivers side under the window?
Old 11-19-2011, 12:02 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
yes
the plastic moulding has a grille looking thing behind the drivers 3rd rear seat. that's the sub. I had my Expy for >1 yr before finding out I had one
Old 11-20-2011, 09:47 PM
ibyers's Avatar
ibyers
ibyers is offline
Do you guys think it might be a loose body mount?
Old 11-21-2011, 11:37 AM
kennisonxgs
That is a possibility as well. Unless the body mount is visually bad, it's going to be very difficult to say it's the cause if the noise is not easily reproducable.
dpeterson3
1983 - 2012 Ranger & B-Series
09-01-2018 08:49 AM
HBO1
1999 to 2016 Super Duty
09-09-2010 10:56 PM
RLB112
06-15-2009 09:33 PM
Arebuilder
1997 - 2003 F150
05-01-2005 10:49 PM
SAR Ranger
07-10-2002 03:03 AM
Quick Reply: 2008 left/rear thump, at a loss.
