Sleeve or no sleeve??? - Ford Truck Enthusiasts Forums
Old 11-19-2011, 07:45 PM
Phinxter's Avatar
Phinxter Phinxter is offline
Phinxter is gaining momentum as a positive member of FTE.Phinxter is gaining momentum as a positive member of FTE.
I'm buying a timing cover gasket kit and you can get it with or without a repair sleeve. So what is the sleeve suppose to repair and how do I know if I need one?
main seal repair sleeve install? rolape2 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 11-17-2011 02:44 PM
Damper Spacer/sleeve 66shortbed 1961 - 1966 F-100 & Larger F-Series Trucks 3 04-18-2010 11:23 AM
rear main seal leak repair sleeve Boz86 1987 - 1996 F150 & Larger F-Series Trucks 0 09-27-2009 06:26 PM
balancer spacer repair sleeve....???? zsir FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 07-27-2005 04:16 PM
Harmonic balancer repair sleeve Ken Swanson Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 11-12-2004 01:04 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
