tire replacement size 4x2 vs 4x4
Hello,
I am looking into new tires and have been wondering about this....
What difference is there if any, between 4x4 vs 4x2 in terms of suspension or tire clearance spacing? The reason I am asking this is because if you go to america's tire.com and enter your vehicle specs., the tire size that they give you for availability differs for a 4x2 vs 4x4. The 4x2 gets sizing up to 275/65R/17 while the 4x4 gets tires up to 285/70R/17. Is there more room in the tire well for a 4x4 vs a 4x2? I always thought that the clearance was exactly the same for both 4x2 or 4x4. A second part to my question is would placing tires meant for the 4x4 on a 4x2 cause problems for the tires?
thanks for your help.
PS i have a xlt supercrew 4x2 5.4 2010
Most of our pickups at work are 2x4's (dodge, chevy and fords), but we always buy All Terrain tires and up-size them to what ever size is availble in a 10-ply.
So, based on what I have seen, there is usually a generous amount of room for up-sizing tires on a 2-wheeler.
Also, 10-ply tires reduce the frequency of flat tires for a fleet to trucks which spend a significant amount of time driving on the shoulder. This is the only reason we use them.
good luck
good luck
I was wondering this too, I verified it at the autoshow this year. 2wd was parked next to a 4x4, the only difference I could see was the approx 1.5" spacer between the axle and leaf spring. The front looked identical and didn't really look any higher other than the slightly larger rubber.
6CylBill
07-06-2009 03:56 PM
