Alternator Wiring
Alternator Wiring
I tried the search function, but didn't find anything that addressed this specifically....
Battery is not charging. I thought I had everything connected properly, but there is one wire coming out of the three wire alternator that is a smaller gauge red black wire with a ring terminal on the end. There doesn't appear to be anything to connect it to, it is too small to connect to the the large studs on the starter solenoid, and too big for the small ones.
It would make sense that it is connected to the Bat. terminal on the alternator... but where does it go? Is this potentially my problem with the charging system?
First question should be do you have factory gauges or idiot lights?
Now, You have the 3 wires connected on the back of the alternator?
Otherwise there is no wire as you describe, at least in the sense for trucks with gauges. I am not thoroughly familar with the idiot gauge circuits and do not have a schematic for that as well.
Here is a gauge style layout, alternator to regulator with harness. No such wire as you describe.
Josh
Josh
Josh
Josh
That appears to be my exact harness... the wire that I am talking about appears to be the one with the ring connector that is near the regulator in your picture.
I stripped the bundle apart to make sure where it went... but still don't know where it goes... this project came to me in pieces (somebody else's headache ) so please pardon my ignorance. It has been a decade or more since I have been inside one of these.
And yes, I have the three connectors connected on the back of the alternator, and the fusible link connected properly to the starter solenoid... I do have gauges.
It's possible the PO of my truck had hacked into it, he did some other weird stuff.
Josh
alright, so I have everything hooked up correctly, replaced the alternator, battery tests good... still not charging though...
Does this sounds like a fusible link problem? Are these symptoms consistent with that? It looks like the fusible link is tied into several wires, how do I connect them to all 3-4 ?
