I have a 61 unibody and I am using the original three on the tree column. I am having real issues finding all of the "guts". For the signal and horn assembly located under the steering wheel. Does anyone have a diagram? Will the parts from a Falcon work?
The plate assembly is metal. Only the switch needs to be replaced if bad. Dennis Carpenter lists the switch for $40.00 PN C0DZ-13341-A I know of no one who carries the complete unit.
If you need the entire unit you will have to scrounge one out of a F100 F250 61 or 62
