Mini-maxx wiring - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Mini-maxx wiring
Old 11-19-2011, 12:30 PM
BigRed03 BigRed03 is offline
BigRed03 is starting off with a positive reputation.
Mini-maxx wiring
Ok, I think i am the worst electrician wanna-be! Reading the instructions on the mini-maxx, says there is a purple wire bundle with the PTO wires by the OBD-II port...found no solid purple but some purple with different tracer colors. My test light does not come on when i test any of these with ignition on. The codes say a VT for ignition 10A on the factory bundled wires.... 2010 F350 with upfitter switches....suggestions to get to the 12V ignition for wiring up the tuner that stays hot during engine cranking? And yes...foaming at the mouth to go to the dark side...help most appreciated - Thanks
Old 11-19-2011, 01:18 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
There's a bundle of wires that have heat shrink tubing on the ends. It's about 8-10 wires. There's a solid purple wire in that bundle.
Old 11-20-2011, 11:55 AM
RM2738 - Thanks....I have more than the 8-10 wires, the purple ones I can not get any type of voltage across them...in my albums, I took a picture of the wires...99% sure these are the ones....yes? Thanks....
Old 11-20-2011, 12:48 PM
RM2738's Avatar
Quote:
That's them. You prob won't get voltage. It's not what actually provides power to the Mini Maxx. It just sends a signal to turn on. The mini Maxx has a switch on the OBDII block that keeps it on or turns on with the ignition signal.
Old 11-21-2011, 10:56 AM
Yep...I am definitely missing the purple wire....looked at my buddy's '09 and he has the specific purple wire for a total of 16 wires...I have 15...I think the factory ran out of purple wire....plan b
Old 11-21-2011, 12:27 PM
RM2738's Avatar
You may be able to use the OBDII block to turn it on manually when you want it on. It doesn't have to be on to function. Only when you upload or need the gauges.
No Power to Mini Maxx zxkevinxz 1999 to 2016 Super Duty 1 11-12-2015 11:34 AM
6.4 blowing white smoke... help please chesterstroker 6.4L Power Stroke Diesel 9 01-11-2014 09:33 PM
Should I update the Mini Maxx offroad? beefcake 6.7L Power Stroke Diesel 11 09-19-2013 03:18 PM
MiniMaxx Wiring F250Snowman 6.4L Power Stroke Diesel 7 05-03-2012 09:08 PM
H&S Mini-maxx w/ EGR Delete kit GRANTSBPACKING 6.7L Power Stroke Diesel 17 01-07-2011 04:01 PM
Tags
12v, 2000, 2010, 64, f350, ford, ignition, maxx, mini, minimaxx, purple, route, run, seic, truck, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
