The starter solenoid can keep cranking (not running) the engine if you've released the key from START and it's stuck. The OP's issue appeared when the OP tried to shut the engine off after running. Completely different situation.
I know it was a different situation. I was asking cause I didn't know if the seliniod could still be energized and keeping it going but now I know! Thanks for clearing it up.
