Tig welding help
As a rule of thumb 3/32" tungsten is a good one for alot of welding, for the your fenders you would probably be better off using 1/16" electrode. A general rule of thumb is use filler rod close to electrode size.
Like Charlie said this a special skill and I guess by your question you have not done much of this welding. I highly suggest you practice alot prior to going after your sheetmetal. A real good soure of info is Jody at weldingtipsandtricks.com.
Good luck.
Good luck.
johnsf
02-14-2006 07:19 PM
