Coolant....
Coolant....
Noticed for the first time today I lost a good amount of coolant in about 10 days. Working on tracking down the issue.
While researching, I found some coolant filtration systems. Curious to see if anyone is running any version in their rig?
Here's one I found...
http://www.amazon.com/gp/aw/d/B005DM9ACO/ref=aw_d_detail?pd=1
What is it about these trucks that requires us to consider filtering coolant? I've driven a lot of trucks, both gas and diesel, and have never had these concerns.
I owned two 7.3's and a Dodge 6.9. Checking oil daily, checking coolant, monitoring temps and getting oil analysis isn't something that was remotely a concern.
I think its a good idea to have one on a diesel engine considering the amount of flow that is pushed through these engines....the 6.0 supposedly had casting sand left behind, but I think its the coolant nitrates breaking down, which in turn clogged coolant passages in the oil cooler and EGR cooler......Cheap insurance if you ask me. I will check with him and get back to you, I think he is still on vacation but I will let you know.
Seems from what I've read, that lots of 6.4's have had episodes of drinking coolant without an explanation. But i'll definitely be investigating it further.
Better get it into the dealer, they will pressure check it and find the leak. One word of caution, if they say it is leaking at the Radiator hoses and NOT the O rings you will not be covered under warranty. Of the two leaks I had the EGR leak made coolant disappear faster than the hoses leaking.
