Front of truck bounces
I have a 1997 f250hd and when I put the brakes on the front of the truck bounces real bad. I had new rotors put on about 10,000 miles ago, put on new calipers and new front brake lines had the rotors turned once.I asked to see how much meat was left on the rotors they said plenty.Well it's back and getting worse could these rotors be that bad again?I can not see anything else wrong hate to change them again they are a pain and to go back to a garage is costly,any ideas would be helpful.
I would look at shocks first. If your shocks are a few years old, they are likely due for replacement.
If the truck shudders only when applying brakes and does not bounce, this could mean that the rotors need to be turned or replaced. Improperly torqued wheel lugs could also contribute to this problem.
My '95 F-250 seemed to enjoy destroying shock absorbers. Rotors seemed to last a long time even though the truck was used for towing.
Lou Braun
Lou Braun
I don't do my own front end work.
I took it to a shop, they also found a bad right inner tie rod. After they fixed all that, my front end drives like new, no more bouncing. Problem had nothing to do with the shocks.
I recently replaced the front rotors on my F150 & noticed the left upper ball joint was loose - when I yanked on the newly installed rotor to check for excessive free play. I had been thinking my front end had been 'bouncing' a bit and was starting to wonder about my shocks.
What I find is that after I work on a truck, and all of the sudden a problem appears, it usually, but not always, means that I did something wrong. So that is the first place I look, and then go from there if that wasn't the problem.
bas157
06-07-2006 09:01 PM
