F250 vs F350 what's the difference? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 11-18-2011, 09:56 AM
Crewcab Turbo's Avatar
Crewcab Turbo Crewcab Turbo is offline
Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.Crewcab Turbo has a very good reputation on FTE.
Does anyone know the difference between a F250 cc 4x4 srw auto and a F350 cc 4x4 srw auto? Is it just springs and emblems? Is there any other changes between the two? Thanks!
Old 11-18-2011, 10:36 AM
SARDiverDan's Avatar
SARDiverDan SARDiverDan is offline
SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.SARDiverDan has a very good reputation on FTE.
That would depend on what year you are comparing them. I have a 02 and they are basically the same for that year; however, different years will give slight variations. If you do a search, this topic has been discussed extensively.
Old 11-18-2011, 12:01 PM
Robert6401's Avatar
Robert6401 Robert6401 is offline
Robert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to allRobert6401 is a name known to all
On the 7.3's, the only difference is the F350 has a 4" block in the rear, while the F250 has a 2.5" block. Now, there are some options available on both like rear overload springs, but that is the only consistent difference. My truck is an F250 with the rear overloads and I added the 4" blocks from an F350 when I installed a 2.5" leveling kit up front. In essence it is the same as a SRW F350 now.
Old 11-18-2011, 12:24 PM
HH60FE's Avatar
HH60FE HH60FE is offline
HH60FE has a very good reputation on FTE.HH60FE has a very good reputation on FTE.HH60FE has a very good reputation on FTE.
Cool guy points. lol
Old 11-18-2011, 01:16 PM
I too have the optional rear overloads and my front lift springs are for a 250 or 350 so basically mines a F350 also I guess. Cool thanks!
Old 11-18-2011, 01:58 PM
Robert6401's Avatar
Don't forget about the all-important 4" block in the rear.
Old 11-18-2011, 02:34 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
BigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud ofBigAlsPSD has much to be proud of
And my 350srw doesn't have overloads, just the 4" block.
Here's a bunch of links.
http://www.ford-trucks.com/forums/11...l#post11046210
Old 11-18-2011, 02:43 PM
Unfortunately I have a 3" factory style block with a 2" factory style block and the rear sits about an inch too low. The PO did some scarry things. I need to lower the front or raise the rear an inch.
Old 11-18-2011, 04:01 PM
traffic142's Avatar
traffic142 traffic142 is offline
traffic142 is starting off with a positive reputation.
Thanks for all the links to the other posts, but I have a 2000 F350, so what was the difference in that and the 2000 F 250? I guess the 1999-2004 F350 vs F250
Old 11-18-2011, 05:26 PM
BigAlsPSD's Avatar
Yes 99-04 will be the same. They are essentially the same, maybe higher rated springs and GVWR but effectively the same in a SRW configuration.
Old 11-18-2011, 06:09 PM
traffic142's Avatar
Thanks for the reply.
Old 11-18-2011, 11:06 PM
Diesel Submariner's Avatar
Diesel Submariner Diesel Submariner is offline
Diesel Submariner is gaining momentum as a positive member of FTE.
GCVM (GCVW)
G'day Fellas,
Been down this path here in Australia.
SRW F250 vs SRW F350 pros & cons. (99.5 - 2003)
Found the same as you fellas that the only differences are.
1. F250 has approx 2" block rear and the F350 an approx 4" block. For more spring travel and an increase in payload hence increase in GVM (GVW).
2. Badges.
3. Higher registration fee and because GVM (GVW) is over 4,500kg (9921lbs) you also require a Light Truck licence to drive it. (I had one but wife had to got do an upgrade on her licence).
I got my F250 ungraded with HD springs and subsequent engineers report to increase the GVM (GVW) to better than an F350 rating.
Seeing I'm paying extra for the registration and have higher GVW than the F250, I've now re-badged mine as an F350..
But like all things there is a trade off. One is as mentioned above the higher registration cost and bigger licence.
The other is that even with a upgrade there is 'no' change to the GCVM (GCVW). That is the Combined weight of the truck and what it is towing.
Nor is there any difference between the factory GCVW for the SRW F250 and the F350.
This is simply because there is no difference in the actual components. Same springs, differential, drivetrain and brake size etc.
So the trade off is even though you can load more into and onto the F350 you can still only end up with a GCVW of 9071Kg (20,000lbs) (same as F250).
A few people who have done GVW upgrades have been trapped by this.
They have loaded up the truck to the new GVW and then hooked up the trailer, caravan, 5th wheeler. They've been pulled over and put over a set of scales and found to be over the legal GCVW.
It's just a point to remember if anyone is thinking of doing this.
The reason I when for an upgrade was that I found with the added accessories on the F250 (canopy (shell), bull bar, rear bar, longrange fuel tanks full, bigger heavier tyres etc; that I'd eaten so much into the payload without putting anything in the back that it was too restrictive. So needed to increase the GVW and hence payload.
Cheers,
Reg
“Political correctness is a doctrine fostered by and illogical and irrational minority, who hold forth the proposition that it, is entirely possible to pick up a turd by the clean end” <O</O
Aussie spec Brazilian built 2005 (US 2003) F-250 Superduty 4x4 7.3Ltr Powerstroke: PHP FU2 6 Pos’n Chip, 6 x ISSPRO Promax Guages, AIS Intake, Zoodad, Cowl Hood, AIH Delete, DIY CCV, BTM muffler, MBRP 4” Black Tip, RiffRaff FRx,HPx,OCR, JWVB, ARB Air Lockers Front & Rear, V10 Tranny cooler in series with Stock Tranny cooler, Deep Tranny Pan, ARB Bull Bar, Edge Evo (for PIDs & Codes only), Long Range Fuel Tank, VMS in Dash GPS Street & Off Road Nav, Toyo OPAT AT 305 70R 16”on 10” Rims, Moog Greasable Ball Joints, Tough Dog Steering Stabiliser, HD Suspension for GVWR (GVM) Upgrade to 5,000Kg.
350 SRW and DRW differences bobv60 1999 to 2016 Super Duty 11 06-06-2015 12:38 PM
Spanked by a 2013 F150 5.0 CC 4x4 CaptainIPSC 6.7L Power Stroke Diesel 29 08-12-2013 09:16 AM
Difference between F350 and F250 SRW SuperDoodieDutyDude 6.7L Power Stroke Diesel 15 06-22-2011 06:10 AM
1995 SRW to DRW axle swap Guiny 1987 - 1996 F150 & Larger F-Series Trucks 6 05-03-2011 05:22 AM
6.4 to 6.2 MB08 6.2L V8 8 04-05-2011 07:03 PM
Tags
1997, 250, 350, aerodynamic, compared, difference, differnces, f150, f250, f350, ford, mods, truck, versus, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
