RECON Projectors Installed!
#46
#47
#48
Quit messing with junk and do it the right way! I have been preaching this for years now haha. Custom retrofit using high quality projectors, ballasts and bulbs. Does it cost more than Recon? I am sure. But we are talking about visibility here. I think that is more important than, lets say brakes. Because if you don't see it, you won't even get to hit the brakes!
#49
Yes three, if the bulbs are 80w/100w, the single post ones were only 55W like the xenon bulbs I already have. If you could give me the part number of the bulbs you are using that should help. I've only looked online and I can't seem to find a single post for 80w/100w. thanks
#50
#51
#52
#53
The high beams are Hella H112 H1 12V 100W
I order from Susquehanna MotorSports www.rallylights.com
#54
#55
If you are somewhat handy, and patient, you can attempt your own retrofit. It is not easy, but not impossible. If you're not interested in doing it yourself there are retro companies that will do it for you. I would estimate that a retro would cost around $900-1000 with you providing the stock headlights. You can do it on your own for $500.
This is not a cheap upgrade, but one you use every single day. I still can't believe Ford didn't release them in their super duties yet. I am sure 2015 will have them .
#56
AMEC - is it your understanding that they only have these modules in smoked glass? I'd prefer clear so it doesn't look modified.
Also - LaxPlaya - you mentioned the retrofits that you've done. Can you give a reason or two why that extra work is better than these Recon pop-ins? It looks like the Recons are around $750, which doesn't seem bad.
Thanks!
Thanks!
#57
#58
#59
