Rebuilt FE 390 (Mirror 105 block) - Video - Ford Truck Enthusiasts Forums
Old 11-16-2011, 09:14 PM
DutchB100's Avatar
DutchB100 DutchB100 is offline
DutchB100 is starting off with a positive reputation.
Fuel leak and p/s leak fixed..
Anyone know where I can get the hose that goes from the charcoal canister to the air cleaner?
1970 Ford F100, SWB, with rebuilt 1973 mirror 105 FE 390 block. Bored .060, stock, Pertronix II, Tefba radiator filter, Holley 4V.
1970 Ford F100 FE 390 Rebuild (2nd run) - YouTube
Old 11-17-2011, 11:51 AM
BlueovalFE's Avatar
BlueovalFE BlueovalFE is offline
BlueovalFE is starting off with a positive reputation.
Gee, couldn't you have taken a little time and at least cleaned up the engine bay a little bit? Looks brand new!
Old 11-17-2011, 10:28 PM
DutchB100's Avatar
Thanks. Almost everything under the hood has either been cleaned/painted, powder coated, or purchased reman/new. Lots of $, but did most the work myself including the rebuild. I had a shop do the heads and bore the cylinders though.
Old 11-17-2011, 10:45 PM
BlueovalFE's Avatar
Sure looks good. Well done.
1970 dist. block parts needed. 70-360fe 1967 - 1972 F-100 & Larger F-Series Trucks 12 04-27-2014 12:36 PM
performer 390 intake/ carb suggestions 70-360fe 1967 - 1972 F-100 & Larger F-Series Trucks 32 04-16-2013 07:42 PM
Help - FE390 coolant leak from exhaust manifold bolt DutchB100 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 04-19-2012 11:19 AM
390 to 460 amosmoses 1973 - 1979 F-100 & Larger F-Series Trucks 14 03-03-2012 12:59 PM
Some 391FT rebuild questions . . . acheda FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 32 01-06-2012 07:01 PM
Tags
105, 1970s, 390, 390mirror, bay, block, engine, fe, fe390, ford, mirror, rebuild, rebuilding, specs, timing, truck, video
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
