Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's SPONSORED BY:
  #1 (permalink)
Old 11-16-2011, 07:22 PM
Traxxis's Avatar
Traxxis Traxxis is offline
1994 Ford Ranger
My Garage
Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.Traxxis has a great reputation on FTE.
1999 Lightning Engine Knock
The problem: A loud engine knock, on the passenger side, around the valve cover, seemingly between cylinder 2 and 3. It does NOT do it at idle, and tends to start around 1900 rpm, and persists until around 3200 rpm. Cruising down the interstate at 70 mph, I can hear it. It primarily does it when the motor is under little to no load, and is noticeably worse when I let my foot off the pedal and coast. Weather and temperature do not seem to have any effect.
The video: Sorry for the fairly poor sound quality, it's difficult to get good audio on a phone with the fan blowing. Don't pay much attention to the video unless you see something glaring as I was mainly trying to focus on the audio rather than where the camera was pointed.
1999 Ford Lightning engine knock - YouTube
All spark plugs have been removed, inspected (well, to the best of my abilities) and replaced. They all have a orangish/brown hue to them. The pictures below show cylinder 1, 2 and 3...
Click the image to open in full size.
(ignore the ghost)
The previous owner (my brother) said it has been doing it for a while, probably 5-6k miles if I were to guess, so I went ahead and made the return trip home from Maryland to Oklahoma in it, which amounted to around 1,300 miles. Thinking it was a lifter and not knowing when the last oil change was, I thought I would give a motor flush a shot to see if I could knock any sludge loose that might be blocking any passageways. Replaced the oil with Motorcraft synthetic blend, and Motorcraft oil filter, but alas, no luck... the knock persists.
The knock is definitely coming from the passenger side, and seems to come from around the number 2 or 3 cylinder. In an attempt to trouble shoot it, I disconnected the coil to number 3 as the motor was running, and the sound was noticeably quieter.
Again, all plugs have been pulled, inspected and re-installed. All plugs are snug (which seems to be the most common fix).
One final note, the motor has spit a plug before, about 30k miles ago. It spit number 2 and was supposedly fixed by Ford. I notice that it is the only one with a different coil too, which would lead me to think they only worked on the one cylinder.
Thanks in advanced. I'll continue combing the search to see if I can run across something else before I pull the valve cover. I also thought about checking the flex plate.
  #2 (permalink)
Old 12-07-2011, 07:26 PM
dlibson's Avatar
dlibson dlibson is online now
2005 Ford F-450
dlibson is a name known to alldlibson is a name known to alldlibson is a name known to alldlibson is a name known to alldlibson is a name known to alldlibson is a name known to all
Well, first thing I would say is piston or bearing problem. Run a compression test first, see if you have good compression on all 4 and if it is even across the 4. If it is, you can rule out head/valve problems for the most part. Then it will be lower end time...
__________________
David
2005 F450 6.0 CC XLB DRW. Sinister Coolant Filter, Blue Spring, Straight Piped, Edge Juice Platinum w/attitude!
1985 Ranger 2WD- 4.6 V8 PI, 91 Front Clip
Tags
1999, 58, engine, ford, knocking, lightning, motor, parts, passenger, plug, roush, sale, side, spark, troubleshooting, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
