Weird oil pressure gauge and engine temp gauge
I think this is my first post, but I'm not even sure since I'm a member of so many forums and I'm the admin at V6F150.com.
I bought the 1980 F100 a couple of weeks ago and only 2 of the gauges work all the time on the cluster. Thankfully one of those gauges is the speedometer and the other is the volt meter.
I'm pretty sure the gas gauge not working is either attributed to the float or something with the sending unit. I can deal with that later and I'll just replace the sending unit.
The problem I'm confused about is between the engine temperature gauge and the oil pressure gauge. I'll start the truck up and the oil pressure gauge will work and give what I feel like is a pretty accurate reading(as accurate as a 31 year old gauge can be). Randomly the oil pressure gauge will just drop to nothing, and the engine temperature gauge will start working. It also happens the other way aroumd(i.e temp gauge works, then goes to 0 and then the oil pressure gauge starts working).
What could be the cause of this problem? I've also read about the 1981-1986 gauge cluster going into the 1980, but I'm not really sure what the benefit of doing this swap would be? I have access to a free and working gauge cluster from a 1983 Bronco, but I'm not trying to dilly dally with anything unless I know it's either better or just a good replacement.
If the pressure gauge didn't read on my F150, you would spend a while with a multimeter and a book trying to figure it out.
I got the oil pressure gauge to work every time the truck turns on, and I found that the coolant temp wire was a little bit stripped, so I wrapped that in electrical tape and grounded it out. The gauge went all the way up, and then down when I un-grounded it. Cleaned the connect on the temp unit and the connector, but I don't think it's doing it's job still, so I assume I should replace the coolant temp sensor.
Now for the gas gauge, when I jump the two connectors on the sending unit plug, the gauge goes all the way up, and I'm having the same problem I am with the temp sensor, except none of the wires are broken, cracked, or stripped on the fuel sending unit wire. I cleaned the connectors up and reconnected. I could either just be really low on gas or the sending unit needs to be replaced?
I assume the temp sensor is probably bad too, correct?
I'm not crying about it either way. I paid $500 for the truck with a rebuilt C4 transmission, put a new battery in it, and it'll cost me $300 to fix all the problems and put new shocks on. Sometimes it's awesome to have friends who work at parts stores.
Anafiel
11-15-2016 11:44 AM
RadioControlGuy85
27
02-04-2016 12:28 PM
Roger T. Pipe
08-02-2012 05:31 PM
Gene W
13
05-12-2005 09:09 AM
John Thomas II
08-30-2004 08:15 PM
