04 makes rattling sound when on the gas.?!? - Ford Truck Enthusiasts Forums
Old 11-16-2011, 03:28 PM
Hendog's Avatar
Hendog Hendog is offline
Hendog is starting off with a positive reputation.
Hard to describe sound, but it only happens under load. It happens at any speed, but more predominently at higher speeds. When I lift off the gas it stops. I can keep it going up hill since I'm maintaining speed rather than accelerating over the limit.
The other day I heard another F150 beside me making the same noise going up a hill. Any ideas?
Old 11-16-2011, 09:08 PM
jennkent5454 jennkent5454 is offline
jennkent5454 is starting off with a positive reputation.
is it like a dieseling sound?
Old 11-17-2011, 02:16 PM
Hendog's Avatar
Quote:
No it's not a dieseling sound.
It's always difficult to describe a sound not knowing the source. It sounds LIKE: glass beads, sand sized, being blown around inside a stainless steel cylinder. It may be a bad bearing, but I've never heard a bad bearing so I could be wrong there.
Old 11-17-2011, 02:41 PM
MCDavis's Avatar
MCDavis MCDavis is offline
MCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputationMCDavis has a superb reputation
With that description, it sounds like the IWE is attempting to engage. Would make sense under hard acceleration as vacuum pressure would be the lowest then. The way to test this would be to do the same but with 4wd engaged. NO sound with 4wd engaged would lead me to believe that you have a vacuum leak. Just don't engage 4wd on pavement, as it could cause unnecessary bind.
Old 11-17-2011, 05:41 PM
Hendog's Avatar
McDavis, you may be on to something. I've engaged the 4WD while going slow and the noise present. The noise went away as soon as I enaged 4WD.
But I don't know what a "IWE" is...?
Old 11-17-2011, 06:39 PM
MCDavis's Avatar
No worries. You really should read this:
http://www.ford-trucks.com/forums/83...then-some.html
Don't blow through it. It's a lot to read, but you'll come out knowing exactly what's wrong and where to look. Enjoy!
Old 11-17-2011, 11:20 PM
Hendog's Avatar
That's quite the write up on the IWE system! Good read!
Well it's going into the dealer on Monday. I fear they'll come back with a bill for new IWE actuators, IWE solenoid, check valves, yada yada yada.
Old 11-23-2011, 01:48 PM
dfishrmn88's Avatar
dfishrmn88 dfishrmn88 is offline
dfishrmn88 is starting off with a positive reputation.
I have the same sound. Just left a mechanics shop I have trusted for years and he said it sounds like a problem either in the starter solenoid or the flywheel.
Well have to have it checked to determine.
Old 11-26-2011, 01:06 AM
Hendog's Avatar
Well, I finally took the truck into the dealer today. I had a few things I needed to get done; put winter tires on (already on rims), oil change, air bag recall 11S18 (wire harness chafe on horn mounting plate), and this "noisy" problem.
It did indeed turn out to be the IWE as McDavis pointed out. Thank you McDavis They replaced the driver's side IWE and the IWE solenoid. It was covered by my extended Ford Base Care warranty.
Thanks to this forum, I bought the warranty from one of the site sponsors when I bought the truck. When I was researching this truck someone said they wouldn't buy one of these trucks without having a warranty. I took that advise and it has paid off. This is the third warranty claim in less than three years (rear diff clutch pack, and intake manifold leak).
Automotive forums are great.
Old 11-26-2011, 06:51 AM
MCDavis's Avatar
You're welcome! Im glad it was nothing more than some IWE issues. Enjoy your weekend!
Old 08-07-2014, 01:46 PM
Kreyton Kreyton is offline
Kreyton is starting off with a positive reputation.
question
Hate to Necro this thread but it seemed relevant to my issues.
I have the exact same issue as OP. Going up hill hear the same sound, level off or gas off sound leaves.
One thing though, if I hit the overdrive off, the sound immediately vanishes. Any reason it would do this if it were indeed the IWE's as well?
Old 08-08-2014, 02:13 PM
cb_13's Avatar
cb_13 cb_13 is offline
cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.cb_13 has a good reputation on FTE.
Lower load in 3rd gear compared to OD. Which results in more engine vacuum, since vacuum is inversely proportional to load.
Old 08-08-2014, 07:04 PM
Quote:
Thanks. that makes sense! my ac blows out of the defroster vents as well under the slightest load so i must have a vaccum leak somewhere, though i dont believe those lines are shared between those two systems. i wonder if the air res. box is? i will check with a gauge to see if it is holding vaccum.
Old 08-12-2014, 01:58 PM
05_AlexF150's Avatar
05_AlexF150 05_AlexF150 is offline
05_AlexF150 is starting off with a positive reputation.
Does yours sound like rumble strip?
Old 09-16-2014, 09:58 AM
chuckczrxoa chuckczrxoa is offline
chuckczrxoa is starting off with a positive reputation.
Crazy, but...
One of the lift bars on my 4.2 was cracked. Took me forever to figure it out. It was the lift bar on the left rear of the engine, that's bolted to the exhaust manifold. I gave it a huge twist with my hands and there was no more rattle.
Until...
Last Friday I kept hearing a rattle. Thought it was from a piece of metal I was hauling. I shifted the load, but nothing changed. Looking under the truck it seemed that the noise was coming from the exhaust. Dang!
Anyway, it seems that looking at it stopped the rattle. (I'm famous for fixing things just by looking at them. No explanation for that, lol)
And the bad news? My engine light is on. Heading to the parts place for a code read now. BRB
And the really bad news? Cat converters for my truck run $550.00 each. Ouch ouch ouch!
Clicking sound from engine/transmission OpenTrackRacer Modular V10 (6.8l) 11 05-23-2016 01:45 AM
Slow Accelleration Jaynen1 Modular V8 (4.6L, 5.4L) 3 07-14-2015 11:54 AM
2008 F150 Mystery Rattle dogshack 2004 - 2008 F150 2 10-15-2014 01:14 PM
Rumbling in drivetrain upon deceleration jspringator Excursion - King of SUVs 6 11-03-2011 03:54 PM
Squeaking clutch? CrazySpyder69 Ranger & B-Series 26 07-16-2006 04:04 PM
Tags
04, 2003, 2006, 2007, 4x4, clattering, expedition, f150, ford, gasing, makes, makesrattling, noise, rattling, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
