Wiring heated seats to remote start?
Ok, so I found a wiring diagram for my heated seats and I'm trying to figure something out...when I turn the ignition on, it triggers a relay providing power to the heated seat switches, so when I push the switch it send power to them. The hot wire after the heated seat switch is a yellow/black wire. Can I just tap into this wire with a relay from my remote start auxiliary wire?
I wouldn't. I would parallel a relay to switch and use the RS to trigger. Basically, spice into the two wires in the heater switch, one to 87a and the other to 30 (power to 87a and 30 toward the elements.) Then find a positive pulse output from the RS, tie into 86 and run 85 to ground.
I would go this method because it allows you choose when you want heated seats and not automatically when you RS.
Does your heated seat not stay on even when the truck is turned off then back on? I have noticed that if my seat heater was on when I shut the truck off, it will be on the next time I start the truck also, this seems to only apply to the drivers side which makes sense.
My 03 did not do that but my 07 does do that.
