Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: 4WD Guides
- Why Can't I Get Into or Out of 4WD?
Guide to diagnose trouble and recommended solutions
How does the superduty 4 wheel drive actually work?
Do you have the switch on the dash or a lever on the floor? If you have the dash switch they're auto-locking unless someone replaced them w/ factory manual lockers. In a King Ranch I would say the manual shift would have been a special order.
I have the switch on the dash. I have had the hubs apart to clean,and re-grease because of the selector being a bear to move. Mostly plastic from what I remember. My friends 02 is a stripped down F350 and has autos. It made me wonder why mine had manuals. I figured someone might have changed them. I just figured the autos were like the hubs we had on our 94 explorer. The auto hubs on it were junk,and I replaced them with manuals.
If the superduty auto hubs are worth it I would be interested in changing mine back. If they fail,I have the manuals to slap in.
Here is where I become a PITA. Can I change them to autos?
Anything special needed to change them?
9 out of 10 transfer case engineers prefer manual shift and manual hubs
You just lock the hubs before you leave if it's snowing or you lock them when you leave the pavement. Mine stay locked for weeks in winter. Costs a little MPG but worth it for reliability IMO. Dodge heavy dutys don't have lockout hubs, they are live all the time. Same for a lot of jeep vehicles.
BS. You had another problem that made it blow. It sure as heck wasn't from wear. There's minimal load on it. If there is oil in it there will be minimal wear. Chrysler used lockouts (or front axle disconnect) sparsely for most of the last decade. Dodge 2500-5500, Jeep Liberty, Jeep Wrangler, Jeep Grand Cherokee WK, Commander, and Dodge Nitro are a few that come to mind where the front is always in.
I have side question. On my new purchase 4WD I had no time to fully test the vacuum, what might have small leak since switching the dash flow takes long time.
So I locked front hubs manually to get out of mud pit, than switched them back to Auto on dry pavement. Yet when making the turn I had the steering shaking indicating the hubs are still connected.
Do the hubs need to go in reverse to make them unlock? Seem it worked when I did it, or did I just got lucky?
We have a work truck that intermittently switches into 2wd with the switch still in 4wd with it in auto on the hubs. My question is, if I want to switch from the auto hub to lock, does the switch on the dash need to be in 4wd, for it to run 4 wd. My mind is that maybe the switch on dash is bad So when we get stuck in the sand, if I just put it into lock on the hubs will that pull us out of the sand if the switch is faulty on the dash or should I leave the switch in 4wd? Thanks for any help. Its a 2007 F250 with auto lock front hubs with the ESOF switch on dash
#28
#29
I've always had manual hubs and a gear shift, and I have never ever had an issue . Lock the hubs when the roads are bad, or when they might get bad.
When things get hairy, put it in 4H. It's really that easy.
