Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 11-16-2011, 12:38 PM
hydmech hydmech is offline
1981 Ford F-250
hydmech is starting off with a positive reputation.
Heater hose restricter
I have a 2011 f350 with the 6.2l gas. The problem I am having is the truck blows cold air at an idle. I installed a greaser in the back that you tap into the heater hoses to circulate hot water thru to keep the grease flowing in the cold temps. If I rev the engine up just a little i.e. 1000rpm or so, It has nice hot air. I have bled this and really run the heck out of it trying to make sure its not air bound. There is a restricter in one of the heater hoses from the factory. Im wondering if I should pull this out? any thoughts on this problem?
  #2 (permalink)
Old 11-16-2011, 02:30 PM
mwsF250 mwsF250 is offline
Garage is empty, add now
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
How about moving the grease heater plumbing to the return line out of the heater core? It sounds like it is currently in the input line.
__________________
'99 F250 V10 Super Cab Long Bed 4x4. '06 short block, PI conversion, modded airbox, 5 Star custom tune, FM50BB, 315/75-16 GY Duratracs, mild lift, 4.30 LSD, Ride-Rite bags, on board air, Rancho RS9000 w/MyRide, under bed subwoofer, 160 amp Quick Start large case alternator
Why, yes, I am some kind of geek engineer. Thank you for asking.
  #3 (permalink)
Old 11-16-2011, 03:08 PM
1981 Ford F-250
Well I have been doing some further testing. I did move the line to both the input and output of the heater core. I also took out the restrictor and put a clear piece of hose so I could actually see what was happpening. I found that when the engine is idling there is practically no flow thru the hoses. Im guessing that it just doesnt have enough omph to push the water?
  #4 (permalink)
Old 11-16-2011, 05:55 PM
That could be.... water pump flow is rpm dependent. Surprising it is that low, but if it is, it is.
__________________
  #5 (permalink)
Old 11-26-2011, 07:20 PM
1981 Ford F-250
Well I actually stuck A flow meter in the hose to see what the actual numbers were..The stock setup it flows 9 gpm at 3000 rpm and less than 1 gpm at idle. I hooked up the grease unit and got 7gpm at 3000rpm and nothing at idle. So I guess there is just to much restriction to be able to do this. So now Im going to try a 12 volt pump and see how that works....The other interesting thing about this is I have done this on a ton of older fords i.e. 2010 and back..never had this problem!..other chevy brands too. Its almost like they detuned the water pump or something..
  #6 (permalink)
Old 11-26-2011, 11:27 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
2000 Ford F-250
My Garage
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
The minimal flow at idle from main water pump is normal.
Because of that all Mercedes cars in last 40 years are equipped with auxiliary water pump that circulate coolant via heater core regardless the engine speed.
I had that pump fail on my car one time and I could feel colder air at stop lights even in 50F winter.
If that bugs you so much, why don't you add this pump to your truck? With some extra wiring you can run the pump and blower with engine off -using engine heat for cabin comfort for about 1/2 hr after engine shut down.
  #7 (permalink)
Old 11-27-2011, 10:13 AM
rwilimo rwilimo is offline
rwilimo is starting off with a positive reputation.
I think your on the right track with the electric water pump, I work on Limousines for a living and we use these to improve rear heat performance, they work great.
  #8 (permalink)
Old 11-27-2011, 11:12 AM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Moved to the 6.2L V8 forum.
__________________
John
2011 F-350 4x4 Lariat Ultimate, Oxford White / Pale Adobe 6.7L PSD 3.55 ELD / Gone but not forgotten.
2013 Ford Taurus SHO, Tuxedo Black / Black Leather
Moderators, Guidelines, and How They are Enforced / FTE Forum Guidelines
Currently truckless
Tags
46, ford, heater, hose, resticted
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
