1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Shift Tube Replacement
Old 11-16-2011, 09:55 AM
dld63's Avatar
dld63
dld63 is offline
Does anyone have replacement instructions for a 99 F250 shift tube?
Old 11-16-2011, 10:35 AM
ccerniglia's Avatar
ccerniglia
ccerniglia is offline
email me at ccerniglia@crowleyauto.net and i'll email you the PDF file. Just hit me with a good rep and we are good.
Old 11-20-2011, 11:32 AM
Jbrown8988's Avatar
Jbrown8988
Jbrown8988 is offline
could you email me this as well. jbrown@landscapesunlimitedcny.com
thanks in advance!
Old 11-22-2011, 07:33 AM
ccerniglia's Avatar
ccerniglia
thanks in advance!
Email Sent. Dont forget the good rep.
Old 11-27-2011, 08:11 AM
dld63's Avatar
dld63
dld63 is offline
Old 04-10-2012, 01:26 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Hey I'd love some instruction on the shift tube replacement too if possible, Can someone upload or send me a link?
Old 04-10-2012, 06:15 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Thanks for the PDF. I converted to JPEG files so I could post online for all to make use of:
http://photobucket.com/shifttubeandbushingRandR
Note that these instructions are for 2003 Excursion and F350.
Old 04-11-2012, 12:51 PM
ccerniglia's Avatar
ccerniglia
Note that these instructions are for 2003 Excursion and F350. Not sure if it varies for earlier models.
As I confirmed with you before over email, it covers about all makes of truck and van from 99-07. MAybe even newer. Can we get a Admin to post this in the tech folder please?
Old 04-16-2012, 06:34 PM
Lex2002's Avatar
Lex2002
Lex2002 is offline
Old 01-11-2020, 11:39 AM
blakeusa's Avatar
blakeusa
blakeusa is offline
Shift Tube Replacement - Parts List Needed
Gonna dig in and fix my floppy shift-er. Just does not sit right and sometimes I have to fidget to get into the right gear.
Bolts are tight and figure that if I take it apart might as well replace all the worn
parts. --- Model 2002 F250 4x4 7.3
Parts
Shift Tube - Ford (F57Z-7212-A)
(2) Shift Tube Upper Bushing - Ford (F3TZ-7L278-A)
Ford Parts Diagram - Steering Column
Should I also replace the lower tube and spring if I have it apart?
Most likely will get Ford OE parts as I have not always had the best experience with non-oe parts for this truck. And price difference online is not that much.
Any other recommendations would be appreciated.
Thed
09-14-2019 07:09 PM
atpst81x
01-19-2010 07:17 PM
deronyv8
09-21-2002 11:56 PM
lumbermansvo
05-10-2001 05:25 PM
Quick Reply: Shift Tube Replacement
