4L, 4H, or 2H? - Ford Truck Enthusiasts Forums
4L, 4H, or 2H?
Old 04-13-2003, 01:46 AM
nak_nak78 nak_nak78 is offline
nak_nak78 is starting off with a positive reputation.
4L, 4H, or 2H?
I am going to be in a mud bog competition next week and I was curious about what to have my truck in. 4H, 4L, or 2H? I wanna get through quick but not get stuck. Which would be preferred? thanx
Old 04-13-2003, 02:47 AM
bronco351 bronco351 is offline
bronco351 is starting off with a positive reputation.
4L, 4H, or 2H?
Well, You definetely would not want to be in 2H!!! If the mud is really thick and deep, put it in 4L. If the mud is not so deep or so thick 4H would be fine!!! Hope this Helps!!!!
Old 04-13-2003, 09:53 AM
mud_man mud_man is offline
mud_man is starting off with a positive reputation.
4L, 4H, or 2H?
I run in 4L all the time in mud pits,I run in a super stock class ,100' 3 sec 20" 30"mud most of time 1st and 2nd with a 6c 200 ' hit 3rd 486 gears and38" tires
Old 04-13-2003, 11:38 AM
fiend's Avatar
fiend fiend is offline
fiend is starting off with a positive reputation.
4L, 4H, or 2H?
I just went through a mud bog the other day for the first time, and all the people who knew what they were doing told me to keep it in 1st gear and 4L. When they wave that flag for you to go, or however they tell you to go FLOOR it and steer straight. Don't let go on the throttle until you stop moving and they tell you to stop.
Old 04-13-2003, 08:31 PM
Tdvjensen Tdvjensen is offline
Tdvjensen is starting off with a positive reputation.
4L, 4H, or 2H?
If you have the manual tranny use 4L 3rd gear and pot the clutch going into the pit and keep the foot down and dont shift. If you have the auto put it in 4L and start in first and go foot down. You could also try and shift it up as you go. I have a bronco with the 4sp that i use for mud so i dont know to much about boggin with an auto.
Old 04-14-2003, 02:44 PM
TallGuy_Az's Avatar
TallGuy_Az TallGuy_Az is offline
TallGuy_Az is starting off with a positive reputation.
4L, 4H, or 2H?
I also mud bog in 4L in third gear, rev it up, dump the clutch and put the pedal to the floor. I don't shift at all through the pit. Of course, if I had a big block I could probably use 4H, 2nd to 3rd. The 300 with my 3.00 gears and 35" tires don't like that too much. 3rd gear in 4L works great, though. It all depends on your gears and engine size along with tire size, because the advice to me with my setup is much different than someone with a 460 and 4.11 gears. Let us know what you have.
What I did before the first mud bog was to go find a big dirt area, put it in gear and try it. That is how I figured what I could and couldn't do.
The other thing is this. If I were to put my truck in 4L and 1st gear, it would take me a good minute to go through the pit if my engine didn't die first and I didn't get stuck. If your truck is like mine with granny 1st, you definitely don't want to do that. Way too low of a gear. Even 2nd in 4L on mine is too low. 3rd is just right in 4L, but even then I could shift if I had more power because it revs pretty high toward the end of the pit.
Hope all of this helps!
Old 04-15-2003, 12:18 AM
bigblue250's Avatar
bigblue250 bigblue250 is offline
bigblue250 is starting off with a positive reputation.
4L, 4H, or 2H?
The old F-250 with the Thornbirds will go thru anything no questions asked (Once I for got to lock the hubs and still made it thru the pit) I think the big 390 has some thing to do with it.Anyway 4HI 2nd or 4lo third
Old 04-15-2003, 08:33 AM
quadzjr's Avatar
quadzjr quadzjr is offline
just another Rockwell looser
quadzjr has a great reputation on FTE.quadzjr has a great reputation on FTE.quadzjr has a great reputation on FTE.quadzjr has a great reputation on FTE.quadzjr has a great reputation on FTE.
4L, 4H, or 2H?
with a f-150 breathing the juice I was always a fan of 4H second gear. You want to get the tries to spin as fast as possible. You just have to play with it. If you don't have the torque to keep them spinning in 4H do a second-third in 4L.
Old 04-18-2003, 11:26 PM
Pkupman82's Avatar
Pkupman82 Pkupman82 is offline
Pkupman82 has a good reputation on FTE.Pkupman82 has a good reputation on FTE.
4L, 4H, or 2H?
In lighter not so deep mud I have found 4H 2nd gear is ideal. For heavier deeper mud 4L 2nd and 3rd gear has worked best for me. Never use granny gear in mud I found out the hard way!
4WD question carlislefordf250 1987 - 1996 F150 & Larger F-Series Trucks 7 03-17-2015 07:27 PM
Please help- 2013 XLT 3.5L Eco front turn signal LED switchback 444BOWHUNTER 2009 - 2014 F150 0 01-28-2015 09:38 AM
NP205 T Case Thunderhorn 1978 - 1996 Big Bronco 3 06-24-2014 10:36 PM
Valley of Fire, NV bpounds S. California Chapter 8 12-18-2013 09:11 PM
97' Expedition 2H and A4WD OK no 4H DAB_Expy 1997-2006 Expedition & Navigator 0 11-27-2010 06:05 PM
Tags
1990, 2h, 4h, 4l, 4wd, 4x4, bogs, drag, f150, gear, gears, mud, preferred, run, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
