Supercab Upper Latch Fix/Access - Ford Truck Enthusiasts Forums
Old 11-16-2011, 04:24 AM
Ningker Ningker is offline
Ningker is starting off with a positive reputation.
2000 Ford F150 SuperCab
Went to fix the latches as the third door does not open. Went to pull the cable to engage the latch but the cable to the upper latch fell off completely.
How do I access the latch to put the cable back in place?
I see a screw that holds the latch but if I remove it, seems that the latch will fall from its location and I don't see a way of getting back up into the upper part of the door.
I have tried a clothes hanger up to the latch and am litterally fishing to hook on something to pull.
Any Help Please......
Old 11-16-2011, 07:02 AM
enriched&beyound's Avatar
enriched&beyound enriched&beyound is offline
enriched&beyound is starting off with a positive reputation.
have you tried a extendable magnet with a flex head?? or a small nozzle on a vacuum??, not sure how much room there is to work with.
there is also those flex grabbers with a plunger on the handle to open....most of this stuff can be found at sears or harbor freight
Old 11-18-2011, 10:36 PM
I am not even sure if I remove that one screw that the door will unlock....
Has anyone had this problem?
How do I open the upper latch if the cable fell off completly?
Old 11-19-2011, 05:26 PM
Sorry not much help..perhaps you can get more help/info to your situation by chatting with a local body shop...I'm pretty sure somebody there can shed more light on your situation...maybe a handy-dandy tool too....or at least a few tricks of the trade.
Old 11-29-2011, 06:49 AM
I didn't have time to swing by any shop but did try to remove the one screw and if anything access it with an extendable magnet as advised, but it didn't budge...
Searched internet again and looks like there are two more screws to remove from the top.
Looks like I can probably wedge it open from the inside but I don't know which way to go (pull or push).
Anyone have an actual picture of their door latch when the door is open?
Would like to see how this thing is situated and then figure out which way to pry when it is closed.....
SuperCab rear doors won't open. Cable / Latch broken bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 32 09-18-2016 05:59 PM
Supercab Lower Door Latch Fixed !!! fbh31118 1999 to 2016 Super Duty 13 10-09-2014 11:26 AM
Custom Latch Panels Wayne Waldrep 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 08-03-2014 06:25 PM
rear door latch Conanski Ranger & B-Series 1 10-27-2011 10:18 PM
Folding the rear seatback (crewcab) rlh68050 2009 - 2014 F150 4 11-04-2010 12:38 PM
Tags
1999, 2000, 2003, back, cable, cables, door, f150, fix, ford, latch, number, part, repair, supercab, truck, upper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
