oil dripping from drain plug
well it seems to be a bad week for me with the slid pins on my caliper and now my oil plug. I changed the oil in my truck from 15w-40 to the t-6 sythentic 5w-40. everything went good until i took it for a test drive and i get back let it sit for a bit. then i notice a oil spot under the truck. I take a look and i see oil slowly dripping from the drain plug. after about 8 hours it forms a puddle the size of a baseball. So i bought a new washer for the drain plug did a quick swap and same problem its still dripping. The bolt it snugged up and the washer is new any ideas of why it would still be dripping. Bolt was brand new from the oil change prior. and it never leaked with the 15W-40. any ideas 02 f-50
Order a Fumoto Oil Drain Valve. I don't exactly know why, but it stopped my leak and many others have had it do the same thing for them. Plus changing your oil will be so much easier from now on!
Riffraff Diesel: Fumoto Quick Drain Valve
I will have to order that valve and give it a try for that price. what can i do in the mean time to stop it from leaking. maybe put some sealant of some sort around it lightly to help stop the leak. I will be heading up north in a couple days for hunting. I dont like heading up there with a leakfrom the drain plug.
The only thing I can suggest is to go to the parts store and try to get a nylon or fiber washer like was mentioned above. It may help. I don't recall if the Fumoto has pipe threads, or what, but I do recall it being a more tight fit, for lack of better words.
If you have a shop vac, I have read that you can use it at the oil filler tube to apply some suction pressure and give you a second to remove the plug and swap the washer, etc, without losing too much oil. Disclaimer, I have never tried this, never had to, but it should work.
It will work, I've done this to change the valve on the bottom of a 275 gallon fuel oil tank. My only suggestion is to not completely tape the hose to the fill tube. If you do, it will suck so much air through the drain plug that it'll probably make the oil foamy. Leave a little space open for it to suck some air.
