Autolite 2100 to Offy "C"- adapter
Is this the correct adapter for the Autolite 2100/ Offy "C" application?
http://www.summitracing.com/parts/MRG-1933/?rtype=10
Mr. Gasket 1933 - Mr. Gasket Carburetor Adapter Kits - Application - SummitRacing.com
Try that and see if it helps.
Those links are the same kit.
As far as I can tell, that's what you're looking for. The only thing I find odd about it is that the base gasket is a 4 hole, instead of a full open. I don't know why you'd want that. Maybe for if you use a 4 hole spacer under it?
If not, I'd recommend you get a full open base gasket to go with it as well.
coolguy1419
11-25-2009 04:46 PM
dgpruitt
07-20-2005 11:10 PM
hellraiser
04-24-2003 01:24 PM
