ANYBODY RUNNING STOCK SETTINGS PROGRAMMER WITH DPFE DELETE OPTION PROGRAMMER - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 11-14-2011, 10:54 PM
BROWN DOG KTM's Avatar
BROWN DOG KTM BROWN DOG KTM is offline
BROWN DOG KTM is gaining momentum as a positive member of FTE.BROWN DOG KTM is gaining momentum as a positive member of FTE.
Is anyone out there running stock horsepower setting with DPFE DELETE Option ??
I'm wanting to try this but my superchips 1850 doesn't offer this.
Is the SCT & superchips the same company ??
Is SCT & Spartan the only two programmers that offers this setup I'm seeking ??
Thanks for your replies
Old 11-15-2011, 05:15 AM
golfmedik's Avatar
golfmedik golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
I'd be interested to know too. If I delete mine, I just want to turn off the regen process. That is all. I don't want added hp due to concerns several have had with their transmissions. My 5er is close to 15k and don't want to hurt the truck.
Old 11-15-2011, 08:04 AM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
this is probably another option:
Gear Box Z DPF-R Ford 4.0 Programmer GBZFD40
DPF-r or the R+.
this is probably what I would consider to just be at stock hp/tq minus the dpf.
Old 11-15-2011, 10:18 AM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
SCT has ceased making the racing tunes, especially those that remove the DPF. As for Superchips, it's actually Edge/Superchips which are the same company, SCT is a different company. Edge/Superchips are no longer offering racing tunes either that remove the DPF.
As for who has the ability to just turn the regen function off, there is Spartan, H&S and GearboxZ offering the ability.
Of those, if your looking for as close to stock with minimal HP gains I would look at the GearBoxZ DPF-R+ which is less the $500 for the tuner and users have reported averaging 18-20mpg regularly (unladen).
Old 11-15-2011, 11:48 AM
JcF204's Avatar
JcF204 JcF204 is offline
JcF204 is starting off with a positive reputation.
I'm looking to do the same thing, which exhaust would you choose? I would like to keep my original Tip to keep any authorities from suspecting anything from a quick visual. And I am confused on whether or not the Cat has to go at the same time.
Never mind, I see that it is DPF on and you need exhaust and tuner if you want more...I read it wrong.
Old 11-15-2011, 03:04 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
you do NOT need to remove the CAT if u remove the DPF, but it is easier to do both at once and not fight the bolts between doc and dpf.
I did the doc/dpf delete.. the stock muffler is straight thru anyhow.. so I kept my rear pipe and tips.
Sam
Old 11-15-2011, 04:19 PM
Quote:
Originally Posted by sdetweil View Post
I did the doc/dpf delete.. the stock muffler is straight thru anyhow ...
I did the AFE Cat/DPFE DELETE & ran stock muffler & tailpipe but HATED the horrible air blowing noise so I used the MBRP 4" muffler with the AFE 4" tailpipe & I'm very happy with this setup
Now IF I can just get my tranny shifting properly ...
I'm LIKING this GEARBOX Z DPF-R as you guys mentioned !!!!!
Old 11-15-2011, 06:00 PM
Upon further reading in the gearbox z dpfr-r,
Looks like it also deletes the egr valve operation ....
Old 11-16-2011, 10:26 AM
smotrs's Avatar
I believe it gives you the option of what what you want turned off but I'm verifying it with someone I know.
Old 11-17-2011, 10:11 AM
Quote:
Let us kno if'n u find out please
Old 11-17-2011, 10:51 AM
smotrs's Avatar
Quote:
Here's the answer I received.
The programmer removes the functions for the EGR from the ECU. So if you do NOT block it off/remove or unplug the EGR it continues to function as normal. If you decide to Block off/remove or unplug the EGR then you will not get engine codes.
Old 11-17-2011, 07:41 PM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
DPF-r or the R+.
It sounds to me the DPF-R /R+ is the only option that doesn't mess with the stock tranny tune too. It appears every other tuner replaces the stock tune and folks may not like the higher performance shift strategies.
Old 11-17-2011, 09:19 PM
The programmer removes the functions for the EGR from the ECU. So if you do NOT block it off/remove or unplug the EGR it continues to function as normal. If you decide to Block off/remove or unplug the EGR then you will not get engine Fcodes.
I'm confused.
If the EGR functions are REMOVED by the DPF-R, then how does the egr continue to function if the coolers are NOT blocked or removed ???
Old 11-18-2011, 10:22 AM
smotrs's Avatar
I believe they just remove the functions that would cause it to throw error codes if you deleted it. Mechanically it would still function but the PCM wouldn't acknowledge it the way it does on a stock tuned truck.
Old 11-19-2011, 06:54 PM
Anyone wanna buy a Superchips 1856 Race Tuner ??
Spartan NGuage js139 6.7L Power Stroke Diesel 2 01-12-2017 05:52 PM
SCT X4 programmer liveWire 7015 Nattyj513 1999 to 2016 Super Duty 2 11-25-2016 08:32 AM
Programmer Just For Changing Tire Size and Speedo Calibration? cdrmotorsports 1999 to 2016 Super Duty 27 02-05-2016 11:48 AM
SCT programmer - EGR Delete tune question white Buffalo 6.0L Power Stroke Diesel 4 09-12-2015 11:21 AM
Worth $100?-Superchips 1815 ctch88 2004 - 2008 F150 0 08-25-2015 12:24 AM
Tags
1996, 49, box, cats, delete, dpfe, dpfr, edge, f150, ford, gear, gearboxz, programer, programmer, removing, review, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
