ANYBODY RUNNING STOCK SETTINGS PROGRAMMER WITH DPFE DELETE OPTION PROGRAMMER - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 12-02-2011, 11:33 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM BROWN DOG KTM is offline
BROWN DOG KTM is gaining momentum as a positive member of FTE.BROWN DOG KTM is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by senix View Post
this is probably another option:
Gear Box Z DPF-R Ford 4.0 Programmer GBZFD40
this is probably what I would consider to just be at stock hp/tq minus the dpf.
Big thanks to you senix
I sold the superchips 1856 for terrible tranny upshifts
I purchased this GEAR BOX Z DPF-R to ONLY delete the filter &
I am Super Happy with it so far.
Now the trans upshifts as it did bone stock.
I think the MPG is going to be better than the
superchips economy tune.
Time will tell ...
Old 12-02-2011, 11:48 AM
aquaman aquaman is offline
aquaman is gaining momentum as a positive member of FTE.aquaman is gaining momentum as a positive member of FTE.
BrownDog, please post back with an update after you've driven it for a thousand miles or so. Interested to hear about any feedback!
Old 12-02-2011, 12:49 PM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
BDK, yeah, keep us informed. I'd be interested to hear whether your getting similar results to what others I've talked to have reported.
Old 12-02-2011, 09:39 PM
Will do guys
Old 12-04-2011, 07:43 PM
mangymarmot mangymarmot is offline
mangymarmot is starting off with a positive reputation.
Please keep us updated on your Gear Box Z DPF-R findings. I'm thinking of going the same route and would like to hear your real world experience before making the change.
Thanks
Old 02-21-2014, 04:17 PM
lroskop lroskop is offline
lroskop is starting off with a positive reputation.
dpf-r
I just installed the dpf-r in my 2008 6.4. seems to run ok but the regen light came on and power dropped. had to shut off truck a couple times and then power came back up. anyone have an answer to this problem?
Old 02-21-2014, 05:10 PM
mich800 mich800 is offline
mich800 is starting off with a positive reputation.
I am in the same boat. I have a stuck egr and wand to do a full delete. Remove the egr and run an aftermarket pipe, not just block off the egr. I think someone here posted they needed to run a jumper capacitor on the old egr harness to keep the computer happy. Can anyone confirm this or can you just leave the harness unplugged with the gearbox z.
Doing more research I think it was the throttle body harness that required the jumper.
Old 02-21-2014, 07:54 PM
GSchretter's Avatar
GSchretter GSchretter is offline
GSchretter is gaining momentum as a positive member of FTE.
SCT 3015 with a tune my buddy has the you can remove DPF and everything from the EGR and comes with 5 tunes
Total cost 367 for SCT and 500 for tunes so 867 heck a lo cheaper than these 1500 tuners that they no longer updates.
Yes I've been running it for 6 months.
No I don't get a cut.
Tunes I have already been updated twice, like to hear when was the last tune these old DPF delete tunes were updated.
No black smoke or hardly any on levels 1-3.
4 and 5 is race tunes and level 3 = +100 hp and +250 torque which is enough for me.
Old 02-21-2014, 10:46 PM
Talking
Quote:
Originally Posted by mich800 View Post
... I think someone here posted they needed to run a jumper capacitor on the old egr harness to keep the computer happy. Can anyone confirm this or can you just leave the harness unplugged with the gearbox z.
Here ya go :
http://www.ford-trucks.com/forums/11...installed.html
Old 02-22-2014, 07:49 AM
Quote:
Originally Posted by BROWN DOG KTM View Post
Perfect, do you know if you still need to do this with the new generation programmer. I called yesterday but tech was not available. I am out of warranty so it is cheaper to go this route than to replace coolers and egr.
Old 02-22-2014, 11:26 AM
Vinford's Avatar
Vinford Vinford is online now
Vinford has a good reputation on FTE.Vinford has a good reputation on FTE.
SCT 3015 R do you mean?
Mine wouldn't work with a 3015?
Or did you tune it yourself?
Old 02-22-2014, 11:09 PM
Perfect, do you know if you still need to do this with the new generation programmer ...
IDK
Spartan NGuage js139 6.7L Power Stroke Diesel 2 01-12-2017 05:52 PM
SCT X4 programmer liveWire 7015 Nattyj513 1999 to 2016 Super Duty 2 11-25-2016 08:32 AM
Programmer Just For Changing Tire Size and Speedo Calibration? cdrmotorsports 1999 to 2016 Super Duty 27 02-05-2016 11:48 AM
SCT programmer - EGR Delete tune question white Buffalo 6.0L Power Stroke Diesel 4 09-12-2015 11:21 AM
Worth $100?-Superchips 1815 ctch88 2004 - 2008 F150 0 08-25-2015 12:24 AM
Tags
1996, 49, box, cats, delete, dpfe, dpfr, edge, f150, ford, gear, gearboxz, programer, programmer, removing, review, running
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
