F350 Tie Rod Replacement? - Ford Truck Enthusiasts Forums
Old 11-14-2011, 06:42 PM
aaronesf aaronesf is offline
aaronesf is starting off with a positive reputation.
Hi all, I have a 1989 F350 and I'm experiencing a couple problems.
When I turn left on a road I feel a slight vibration. Is it just the boots that are the problem? How should I go about fixing this?
Well let me show you some pics.
Standing facing the front of the car,
Left Tie Rod (Bad One)
For comparison, the right one (Good one)
Power steering connection
Closer look of power steering boot
Old 11-14-2011, 06:53 PM
danr1 danr1 is offline
danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.danr1 has a great reputation on FTE.
The boots are a problem yea however if there is play in the joint it need be replaced as a unit, tie rod end will include a new boot naturally.
If the joint is tight and is greaseable type you could just replace the boot if you can get one, however usually when to that point the damaged boot has allowed dirt in damage is already done. Unless of course excessive amount of play in the joint to start with was the reason for the boot failure/damage.
Even the joint pictured with the fully intact boot, that joint might be worn out regardless of boots apparent condition.
Only way know is check everything over for play.
Old 11-14-2011, 07:06 PM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
The one at the pitman arm (the right inner tie rod) looks like it has had a pickle fork used on it to seperate it, ripping the boot. The nut looks like it has just been removed also.
Old 11-14-2011, 07:35 PM
Yeah there is play in all of the joints pictured. Looks like an expensive repair. Great.
Old 11-14-2011, 07:38 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
New tie rods ar about 30-40 a piece. Dont forget a toe set afterwards
2007 Ford F350 XLT Diesel White - $8,500 Hellbringer Vehicles for Sale 0 02-07-2017 08:08 PM
1980 F100 stepside restoration crestfallinman 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 110 10-21-2015 03:20 PM
Need help identifying WD hitch Rovernut Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 10 07-06-2015 09:39 PM
New drum brake judder Rovernut Brakes, Steering, Suspension, Tires, & Wheels 26 04-01-2013 03:30 PM
Relay box fuse # 20 ? Diesel32 6.0L Power Stroke Diesel 10 04-06-2011 10:52 PM
Tags
1996, 1999, 2002, 350, aftermarket, duty, end, f250, f350, ford, replace, replacement, rod, rods, suoper, tie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
