temperature gauge and fuel gauge not working - Ford Truck Enthusiasts Forums
Old 11-14-2011, 02:29 PM
beckman beckman is offline
beckman is starting off with a positive reputation.
hi guys i have a 1971 ford 3/4 ton truck i just replaced the fuel sending unit in the tank and it was working the gauge and the sending unit and the temperature gauge was also working now i dont have temperature or fuel gauge working any ideas would be greatly appreciated thank you
Old 11-14-2011, 07:34 PM
CougarJohn CougarJohn is offline
CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.CougarJohn has a good reputation on FTE.
The common element in your problem is the CVR- constant voltage regulator- which is a small item in the dashboard that keeps swings in alternator voltage from reaching the gauges. The guys will be in soon to tell you how to get at it for your particular truck.
Old 11-14-2011, 10:58 PM
Thipdar's Avatar
Thipdar Thipdar is offline
Thipdar has a good reputation on FTE.Thipdar has a good reputation on FTE.
Quote:
It's probably important for you to let us know whether your dash has indicator lights or gauges.
IIRC, the CVR works with either instrument cluster, and it's the prime suspect.
Also, do you have dual tanks? If so, there's a tank selector switch that feeds the signal from either tank sender to the sole fuel gauge.
It's possible (but not likely) that you have two problems. If R&R -ing the regulator fixes both problems, you've got it licked; otherwise, you'll need to do some more sleuthing.
Old 11-15-2011, 12:32 AM
cvr
hi guys thank you for the replies i appreciate it it has the gauges in my dash
how do i test the cvr and how much is a new cvr thank you
Old 11-15-2011, 12:43 AM
Thipdar's Avatar
You'd likely need an electronics lab to see if the thing's still in spec. Dunno if I've ever heard of a test for it.
LMCTrucks.com has it for $50. I was looking at it today... I need one too
EDIT:
Page 79, item 34 for years '67-'69 $30
Page 79, item 35 for years '71-'72 $50
That lets me out, I need the one for 1970! (sheesh!)
Old 11-15-2011, 12:13 PM
gauges work
well found location of constant voltage regulator removed 1 screw holding onto the back of the instrument cluster and bingo turned the key gauges work thank you everyone for the help
Old 11-18-2011, 07:08 PM
Thipdar's Avatar
Yeah, I pulled mine out as well. Turns out it looks like the '71-'72 part.
Had to pick my son up from High School before I could get the instrument cluster reinstalled. When he noticed the big gap in the dashboard, he said "Ok, THAT's casual!" I then explained to him that there's a lot of stuff that you don't really need in order for the truck to run.
It made me wonder - Will the new trucks run if you remove the instrument cluster, or does the computer freak out and choke up?
Old 11-20-2011, 01:04 AM
crazy horse 69 f100 crazy horse 69 f100 is offline
crazy horse 69 f100 is starting off with a positive reputation.
yeah you are lucky . I thought that was my problem, but none of my gauges work , so I have a big electrical headache, glad you got yours fixed.
Old 07-10-2014, 09:17 PM
dbreienrk1 dbreienrk1 is offline
dbreienrk1 is starting off with a positive reputation.
Similar question...
I own a '67 F600 330ci and my tachometer, fuel gague, speedometer, alternator gauge and oil temp gauge all work. Unfortunately, my temp gauge is the only faulty one. Any ideas on how to troubleshoot? Thanks!
Old 07-11-2014, 12:39 AM
orich's Avatar
orich orich is online now
orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.orich has a great reputation on FTE.
Quote:
Remove the temp wire from it engine sending unit and touch it to ground for just a few seconds, if the dash gauge is working it will go all the way to hot
when grounded. Best to have a helper so you can watch the gauge..
So replace sender if gauge is good.
Orich
Temperature sending unit 86 F150 Dylan86f150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 10-18-2015 06:55 PM
Temperature gauge inaccurate? supertwin1 1968-2013 Full Size Vans 24 10-06-2015 09:25 PM
temp gauge not working easyridin 1987 - 1996 F150 & Larger F-Series Trucks 3 08-29-2015 06:24 PM
mustang gas tank sending unit/ ground? jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 07-23-2015 10:44 AM
Gas and Temperature Gauge Issues JD_F100 1967 - 1972 F-100 & Larger F-Series Trucks 26 08-31-2014 11:26 AM
Tags
1977, 1994, 2008, explorer, f100, f150, ford, fuel, gas, gauge, guage, registering, tank, taurus, temp, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
