Fan Clutch Removal
Old 11-14-2011, 01:07 PM
skoveng's Avatar
skoveng
skoveng is offline
Fan Clutch Removal
When facing the truck, do you turn the fan clutch nut left or right to remove? Thanks in advance!
Steve
Old 11-14-2011, 01:15 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,098 Likes on 998 Posts
Did you know that when determining Right and Left on ANY vehicle, that it is as if you are sitting in the drivers seat? I do believe that that nut is a standard right hand thread tho.
So tighty is righty.
Old 11-14-2011, 01:31 PM
skoveng's Avatar
skoveng
skoveng is offline
Bud, thanks for the reply.
Yes, I do know that right and left is determined from sitting in the vehicle; the fan clutch is a little hard to reach from in there tho! (lol) As I figured most people will be facing the truck when removing it, I asked the question from that point of view.
Thanks again!
Steve
Old 11-14-2011, 01:34 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Welcome Steve.... I like to throw in little bidbits when I can....others can learn, right? Have a good day!
Old 11-14-2011, 06:00 PM
Sheryle's Avatar
Sheryle
Sheryle is offline
Talking
Probaly TMI but I had to remove mine last year. The nut is left to loosen facing the front bumper. Mine was a real PITA. Some folks get it with no problem. I tried everything from buying a removal tool from NAPA and using the strongest air hammer Snap On had... to beating it with a 8 lb hammer. Would not budge. I am not trying to discourage you just a heads up. I decided not to stress over it and went on to other projects. No. it did not remove itself. For the next 2 days anytime I walked close to the X I hit the bar with a BFH once or twice and moved on. Second day second try it broke loose and you could turn it off with your hand. ......Good luck...
Old 11-14-2011, 07:43 PM
fixxxer-upper's Avatar
fixxxer-upper
fixxxer-upper is offline
FTE Fan
A pipe wrench worked great for me the last time I had to remove it.
https://www.ford-trucks.com/forums/8...pump-info.html
Old 11-15-2011, 07:29 AM
skoveng's Avatar
skoveng
skoveng is offline
Thanks for the info men.
Steve
Old 11-15-2011, 09:07 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
I have given up on the left/right thing. I see people mix it up sometimes. I use driver/passenger side. No confusion.
Old 11-15-2011, 01:58 PM
Mr. Sandman's Avatar
Mr. Sandman
Mr. Sandman is offline
What they said...righty tighty, lefty loosey and I used a pipe wrench with a breaker bar as well. The real trick was holding the pulley from turning. I finally was able to do so with a long 1/2" drive extension with 3/8" adapter on the end and in the hole but only after wasting two large, perfectly good screwdrivers.
brandon.edwards
03-23-2014 08:45 PM
Jayme Duty
21
07-18-2011 08:54 AM
e-z
General Diesel Discussion
05-12-2008 01:01 PM
RangerPilot
1983 - 2012 Ranger & B-Series
31
07-31-2006 09:21 PM
Paulstinkerinnow
01-20-2004 02:15 AM
Quick Reply: Fan Clutch Removal
