Fan Clutch Removal - Ford Truck Enthusiasts Forums
Fan Clutch Removal
Old 11-14-2011, 01:07 PM
skoveng skoveng is offline
skoveng is gaining momentum as a positive member of FTE.
Fan Clutch Removal
When facing the truck, do you turn the fan clutch nut left or right to remove? Thanks in advance!
Steve
Old 11-14-2011, 01:15 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
Did you know that when determining Right and Left on ANY vehicle, that it is as if you are sitting in the drivers seat? I do believe that that nut is a standard right hand thread tho.
So tighty is righty.
Old 11-14-2011, 01:31 PM
Bud, thanks for the reply.
Yes, I do know that right and left is determined from sitting in the vehicle; the fan clutch is a little hard to reach from in there tho! (lol) As I figured most people will be facing the truck when removing it, I asked the question from that point of view.
Thanks again!
Steve
Old 11-14-2011, 01:34 PM
BPofMD's Avatar
Posting Legend
Welcome Steve.... I like to throw in little bidbits when I can....others can learn, right? Have a good day!
Old 11-14-2011, 06:00 PM
Sheryle's Avatar
Sheryle Sheryle is offline
Sheryle is gaining momentum as a positive member of FTE.
Talking
Probaly TMI but I had to remove mine last year. The nut is left to loosen facing the front bumper. Mine was a real PITA. Some folks get it with no problem. I tried everything from buying a removal tool from NAPA and using the strongest air hammer Snap On had... to beating it with a 8 lb hammer. Would not budge. I am not trying to discourage you just a heads up. I decided not to stress over it and went on to other projects. No. it did not remove itself. For the next 2 days anytime I walked close to the X I hit the bar with a BFH once or twice and moved on. Second day second try it broke loose and you could turn it off with your hand. ......Good luck...
Old 11-14-2011, 07:43 PM
fixxxer-upper's Avatar
fixxxer-upper fixxxer-upper is offline
FTE Fan
fixxxer-upper has a good reputation on FTE.fixxxer-upper has a good reputation on FTE.fixxxer-upper has a good reputation on FTE.
A pipe wrench worked great for me the last time I had to remove it.
http://www.ford-trucks.com/forums/86...pump-info.html
Old 11-15-2011, 07:29 AM
Thanks for the info men.
Steve
Old 11-15-2011, 09:07 AM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
I have given up on the left/right thing. I see people mix it up sometimes. I use driver/passenger side. No confusion.
Old 11-15-2011, 01:58 PM
Mr. Sandman's Avatar
Mr. Sandman Mr. Sandman is offline
Mr. Sandman is starting off with a positive reputation.
What they said...righty tighty, lefty loosey and I used a pipe wrench with a breaker bar as well. The real trick was holding the pulley from turning. I finally was able to do so with a long 1/2" drive extension with 3/8" adapter on the end and in the hole but only after wasting two large, perfectly good screwdrivers.
Removing fan clutch 1984 I-6 redbayredneck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 08-22-2016 05:08 PM
Fan clutch fluid Mikerage 1997 - 2003 F150 5 07-09-2016 06:42 PM
Electric Fan? Casey02L Modular V10 (6.8l) 17 03-29-2012 09:29 AM
Fan removal VAXB Modular V10 (6.8l) 20 11-24-2011 09:33 AM
Fan Clutch cornking Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 09-23-2010 03:13 AM
Tags
150, 1980, 29, 54, 60, clutch, fan, ford, internationalfanclutchremoval, left, lose, nut, ranger, removal, remove, thread
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
