Drivers side fuel filter question
Old 11-14-2011, 12:47 PM
droffan's Avatar
droffan
droffan is offline
what kind of tool is used to "drain the water" before removing the cap. is there such a item? there seems to be a "allen wrench fitting", is this correct?
Old 11-14-2011, 01:10 PM
robert421960's Avatar
robert421960
robert421960 is offline
yes correct
Old 11-14-2011, 01:12 PM
j4henry's Avatar
j4henry
j4henry is offline
6mm Allen I believe
Old 11-14-2011, 01:17 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
And before you take it out, get a replacement for it. They tend to strip.
And the way the fumoto hangs out, you get a better flow control. Less mess.
Fumoto valve:
Ford part number: 6E7Z-9C082-A
International part number: 2589259C91
List price is around $16.00
Putting an end to this insanity - PRICELESS!
DTS Articles - HFCM Water Separator Drain Plug Upgrade
Since you are doing your own fluid changes, maybe think about a Fumoto oil drain valve also.
F-111 or F-111N which has a nipple for a hose to drain your oil into.
http://www.amazon.com/Fumoto-F-111-E.../dp/B003VCES9I
I needed a new copper washer for my drain plug on a past change, they charged me $15 for the stupid thing. Not anymore!
Old 11-14-2011, 04:03 PM
phantomphixer's Avatar
phantomphixer
phantomphixer is offline
Does anyone know the thread size of the HFCM drain plug? I'm looking to replace my HFCM drain plug with a Fumuto quick drain and not have it run down to my armpit. I always drain mine during oil change and oil change is 600 miles out.
This seems like a better idea than Ford has with their upgrade plug and you can control it a hell of a lot better. Into a jar instead of all over the place.
Old 11-14-2011, 04:49 PM
Dieselpop's Avatar
Dieselpop
Dieselpop is offline
I have the new quick drain plug no problem it runs down the plug into a large mouth peanut jar drain out about 1-2oz once a month no problem if you install the quick drain of some kind it will leave some water in because it will be higher than the threads not a lot but higher.
pop
Old 11-14-2011, 07:14 PM
BobbyB's Avatar
BobbyB
BobbyB is offline
I have a small funnel that has one side higher than the other. I tape one end of the funnel in a 20 ounce bottle. The other end sticks up between the drive shaft and HFCM with the high side of the funnel against the drive shaft. When I remove the plug, the fuel hits the high side of the funnel and runs in the bottle, hardly ever makes a mess.
Old 11-14-2011, 08:01 PM
zhilton's Avatar
zhilton
zhilton is offline
amdriven just posted this a couple of posts up from yours...
Fumoto valve:
Old 11-15-2011, 12:26 AM
amdriven2liv
I think he is looking for a fumoto like valve that is used for the oil drain to put on the water drain plug.(flick the lever) Not sure it would get the lower part of the area drained though. Seems like it would be a little higher.
Edit: (As I see Diesel pop has also mentioned)
Old 11-15-2011, 10:45 AM
zhilton's Avatar
zhilton
zhilton is offline
Yeah, I think those part numbers I re-posted were the upgraded HFCM water drain plugs.
I never put the two side-by-side but I'm wondering if the water drain plug & test port plug (on secondary filter housing) are the same size/thread? Off the top of my head, they seem very similar (same 6mm hex size), but like I said, never had both next to each other.
Old 11-15-2011, 01:33 PM
phantomphixer
See this post about Fumoto HFCM drain.
https://www.ford-trucks.com/forums/1...ain-maybe.html
Courtney Williams
03-01-2013 03:14 PM
GeneLaw1
05-16-2012 01:06 AM
farmlucki
07-20-2009 09:37 AM
oldfordtrucksrule
Oil & Lubrication
17
01-02-2007 04:01 PM
FloridaF250
1999 to 2016 Super Duty
09-28-2006 06:39 AM
Quick Reply: Drivers side fuel filter question
