Hard starts and white smoke - Ford Truck Enthusiasts Forums
Old 11-14-2011, 12:01 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4 86f250XLT-4x4 is offline
86f250XLT-4x4 is starting off with a positive reputation.
I have an 86 6.9 idi t19 4x4 regular cab that I recently saved from being crushed and other than my turn signal issue she is almost always a pain in the a$$ to start I know getting the glowplugs working would help alot but Saturday it was 60 f outside and it still wouldn't start without ether and while trying to start I can smell fuel! (after a few cranks) but it won't fire and when she does fire up she runs real good but under hard acceleration or hauling a load she puts out white smoke... Just enough I can smell it in the cab and see a little behind me... I am going to run diesel kleen through it but does anyone have any other suggestion for me to check till I get my glowplugs fixed?
Old 11-15-2011, 08:49 AM
Bump^^^^^ no one ???
Old 11-15-2011, 10:02 AM
Rollin.IH.Coal Rollin.IH.Coal is offline
Rollin.IH.Coal is starting off with a positive reputation.
I know you already made sure there was no leaks or air introusions right? caps and return lines? i would almost always blame air or bad IP on hard start. i guess you could throw in an epump to prime before start. i did but my trucks in pieces still lol!
Old 11-15-2011, 11:34 AM
eatont9999's Avatar
eatont9999 eatont9999 is offline
eatont9999 is starting off with a positive reputation.
Are you saying you get white smoke after she is warmed up? Lots of white smoke after starting with no GPs is normal but after operating temp, you shouldn't have any smoke.
Old 11-15-2011, 12:15 PM
I have white smoke at full operating temp when under a load like when I get into her she smokes a bit of white smoke.... As for the hard start I have an e pump and I check the schrader valve before cranking with e-pump on and before I got air and foam now all I get is fuel but she still won't start without ether
Old 11-15-2011, 12:16 PM
Forgot to say won't start without ether when cold but I'm talking like low 60's and won't start without it
Old 11-15-2011, 12:20 PM
dieself250 dieself250 is offline
dieself250 is starting off with a positive reputation.
Does the cold timing advance work? Pump timing could be off a hair and could have week injectors
Old 11-15-2011, 12:57 PM
Weak injectors and ip wouldn't surprise me at all
Old 11-15-2011, 01:12 PM
eatont9999's Avatar
From what you have said, it looks like you need new GPs and or GP controller for the hard starting. Even if it were 100F outside, it will still start hard without GPs.
Next, you should look into return line leaks and possibly overhauling the injection system. You may just need to advance your timing a little to get rid of the smoke at operating temp. I guess that really depends on the condition of your IP and injectors.
What did you pay for the truck if you don't mind me asking?
Old 11-15-2011, 01:36 PM
$750 it has a decent flatbed on it and so far I have only spent $34 on things and that's only because I put led tailights on it and some bolts for the front bumper and I have looked at the return line system on the truck I don't see any fuel anywhere except when I push the schrader valve here soon the gp system will be on a push button just like my other truck. (that is sadly still waiting on engine rebuild) I decided to not transplant the motor from the flatbed so the other truck can have more done to it
Old 11-15-2011, 01:47 PM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
YUP it don't matter how warm a day it is, it still takes working gp's to start the first time of the day, or anytime it has cooled down to outside temps.
Old 11-15-2011, 03:36 PM
I will be fixing that soon! Ran into a new issue though when I get into her then let off she seems to die.... Idk maybe low fuel we will see here soon though
Old 11-15-2011, 04:12 PM
eatont9999's Avatar
Quote:
It could be low fuel. When was the last time the fuel filter was changed?
Old 11-15-2011, 05:10 PM
Low fuel is why she died lol I got some fuel in her and she was better fuel filter needs changed I pulled it to see how low it was and it has something black at the bottom
Old 11-15-2011, 07:00 PM
As long as I remember, when my dad bought a used vehicle. He would stop at a lube shop on the way home, and have all fluids and filters changed, before he even got it home the first time. I have pretty much stuck to the same policy, except I generally bring it home and do it myself, including the rearends.
When I pull a fuel filter, I stick a new one back on, 6.9 filters are cheap compared to any component of the fuel system, and tolerances are tight in them.
Truck randomly stalled, glow plug light won't come on, truck cranks fine but won't fire 90Ford73 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 07-23-2016 07:02 PM
Properly treated fuel, New Glowplugs and UVCH -4F. NOT plugged in ExPACamper 1999 - 2003 7.3L Power Stroke Diesel 17 03-19-2016 10:58 PM
Using A Resistor In Place Of A Glowplug 1972RedNeck Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 01-30-2016 09:19 AM
Rollin Snow in Winter (white smoke question) Glowplugger 1999 - 2003 7.3L Power Stroke Diesel 9 11-10-2015 12:54 PM
1994 f350 turbo idi smoking ?'s donfordman Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 04-09-2014 05:48 PM
Tags
1983, 69, 73, 73l, diesel, excursion, f150, f250, ford, hard, smoke, smokes, start, starts, truck, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
