Project: Smogie...RacinNdrummins IDI build
Old 05-08-2013, 12:05 AM
RacinNdrummin's Avatar
RacinNdrummin
RacinNdrummin is offline
Originally Posted by southtexasidi
Nice. Where'd you get the bushings for the traction bars from?
Local 4x4 shop, they are for some sort of chevy application, leaf springs or something, either way, very common...
  #782
Old 05-08-2013, 12:06 AM
RacinNdrummin
Originally Posted by hairyboxnoogle
Justin what did you have to do for the T-case output shaft to make it work with the OD unit?
It was the same spline as the OD input, lucked out there... Just had to build the tailshaft housing...
  #783
Old 05-08-2013, 12:08 AM
RacinNdrummin
Originally Posted by turtlemann14
who's od is that?
Its a Doug Nash DNE2....
NMB2 and I found it at the JY one day... It was like $50 out the door, and sat on Justin's shelf for a while, before I bought it off of him.
  #784
Old 05-08-2013, 12:10 AM
RacinNdrummin
Originally Posted by NMB2
building an x-member for that OD unit I assume?
Oh yes LOL.... It hangs out like 3ft from the tranny crossmember.... I could see that thing on the ground in no time without a Xmember...lol...
  #785
Old 05-08-2013, 12:18 AM
RacinNdrummin
Here is tonights progress...
Got my spring plates done:
Then I started putting things together. Got the rearend in, little Misc. stuff painted, and the tank in:
Tomorrow I am headed to the track to get some time on my bike, but thursday I will probably get the hard parts wrapped up, maybe get my water tank finished. Then I can start fabbing my traction bars, and drive shaft, get the bags mounted, and start plumbing things... After all that its off to the fron of the truck to get the fun stuff done.
More soon...
  #786
Old 05-08-2013, 05:51 PM
turtlemann14's Avatar
turtlemann14
turtlemann14 is offline
what type of paint?
and dam that is a big fuel tank lol
what shocks are you running?
on an un-truck related note, do you like that everlast welder/cutter?
  #787
Old 05-08-2013, 06:55 PM
RacinNdrummin
Just Krylon Fusion Satin Black, It covers real good, and holds up nice. The tank is done in Hammerite, and the shocks (which are just Pro-comp ES5000's??) and rear cover (as well as T-bars will be be) are painted a similar color to my truck.
As far as the Everlast stuff goes, I have had my Tig for almost 4 years, has all the bells and whistles, I upgraded to CK torches the day I got it in the mail, and it works as good as any Miller or Lincoln Ive ever used, only chinky part is the pedal. I also have a 50 amp plasma, and it works well also. Have had that for 3 years or so, but it doesnt get used as much as my tig, and the only only thing ive had to do to that is pop the air solenoid apart and lube it after I ran too wet of an air charge.
Overall, If you can afford blue, buy blue, however, if a cheaper machine is all thats in your budget (like it was when I bought them), dont hesistate to buy an Everlast, they have treated me good. And this is coming from a guy who can afford to buy the better stuff now, and probably will if these ever crap.
  #788
Old 05-12-2013, 12:51 AM
RacinNdrummin
Ok... Just a few pics and a little elaboration...
It doesnt look like much work was done, but it was a lot. Got the brakes done, little stuff mounted, and the bags on... Tomorrow will be traction bars. I have had the truck outside because we have had about 10 days of sunny 70* weather, its supposed to rain tomorrow, and being Washington, that means July 5th will be the next sunny day, so I had to put it back in the garage.
Its not show quality, but not too many 88 F250's get this sort of work put into them....
  #789
Old 05-12-2013, 01:36 AM
Fordidipower's Avatar
Fordidipower
Fordidipower is offline
Is it sad that I look forward to sat night to read the progress of this thing?
  #790
Old 05-12-2013, 09:20 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
'94IDITurbo7.3 is offline
lookin' pretty decent man....
  #791
Old 05-12-2013, 10:21 AM
turtlemann14
lol i think we all do
no forward fuel tank?
  #792
Old 05-12-2013, 11:35 AM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Its a great looking truck. I would say one of the best out there for 88. Keep it up.
Chet
  #793
Old 05-12-2013, 11:37 AM
'94IDITurbo7.3
the front tank will be his water meth tank...
nice *itch bags.......
is see you modified the factory place for the leaf springs for the bags. did you do a full custom top bracket as well? what brand of bags?
  #794
Old 05-12-2013, 09:08 PM
RacinNdrummin
Chet
Thanks for all the good words guys.
  #795
Old 05-12-2013, 09:13 PM
RacinNdrummin
Yup, front tank is a custom 30gal stainless water tank.
Never heard them called Bitch bags before, is that a common term?? Oh well, guess im a bitch....
Modified the spring plates to bolt the bags to, I dont like clutter, and the bolts that come with them just look like *** IMO... The uppers are just the bracket that came with the bags. They are Firestone Riderites that I pulled off a truck at the JY for dirt cheap, and they have been kicking around for about a year
Quick Reply: Project: Smogie...RacinNdrummins IDI build
