Project: Smogie...RacinNdrummins IDI build
#1966
#1967
Well Racin's truck with the old set up and his new heads bolts or o-ring would be a great set up for all. Believe be it cooked. He seems to be going in a different direction now I personally wish he wouldn't. I know he can make more power but the cost is way more. Anyway I'm still watching this thread.
#1968
#1969
I don't quite follow the logic that folks are getting let down by seeing this thing go P-pump instead of the DB4 and supercharger route. If Smogie holds together with the P-pump then I think we will have the answer about whether it would have held with the maxxed out DB4 set up. Just because it is a highly custom set up beyond the fabrication skill level and budget of the masses, does not mean we don't get the answers we seek for our own builds. The higher Justin pushes the envelope on the IDI, the more we all get to learn about its limits and limitations. I see this as purely a "win".
The P-pump aspect isn't going to limit what comes from anything else. its just extra frosting... Im just making the frosting before I bake the cake!
#1970
Even though its not specific to Smogie anymore, The turbo kit is finally finished and is going on my Friend Keith's truck. He lives a couple miles from me, and already has my 90, injectors, cam, and girdle kit on a fresh IDIT in an 86 F250.
We are dropping my turbo kit on it, was well as a modified HX35 (Drilled/Enlarged WG, bigger puck, etc.), and we are going to be fabbing the prototype IC kit and intake today.
Ill get some pics up tonight.
#1972
#1973
#1974
#1976
Ok. So with a normal setup, like the factory turbo or even bigger, the SD IC will not be restrictive, right?
#1979
For a mild build a stock IC would probably be fine. Guy i work with has his factory IC in his 02 dodge, all he does is haul wood with it, probably 500-600hp says it only gets warm on hot days. Thats with a single super B. But if you have the coin, or want to get crazy, Its an upgrade i would consider.
#1980
