Injection Control Pressure Sensor ( ICP SENSOR ) Help
Old 03-15-2012, 10:39 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
You can test it before removing. It was known to be bad, so it was replaced.
  #32
Old 03-16-2012, 09:07 AM
BigTires's Avatar
BigTires
BigTires is offline
nice write up.i was wonderin is there a way to test the connector for the ICP? i have oil on my connector and was wondering if i can just clean it or if i need to replace the connector.
  #33
Old 03-16-2012, 09:55 AM
woodnthings
If the connector has oil on it, you can clean it. The question you need to answer is: Where is the oil coming from? Most likely the ICP sensor is leaking internally and causing the oil to weep into the connector.
If you need a new connector, Riffraff Diesel has you covered!
Riffraff Diesel: Ford ICP Pigtail Harness
  #34
Old 03-16-2012, 10:35 AM
nlemerise's Avatar
nlemerise
nlemerise is offline
Great job Ken...
  #35
Old 03-16-2012, 10:47 AM
BigTires's Avatar
BigTires
BigTires is offline
ok ill clean it up. its coming from the ICP sensor its bad i have had in there less then a year not sure why it failed must be beacuse it was one igot on ebay with the adaptor on it.
i jsut wanted know how to know if the connector is bad and in need of replacing when i put in the new ICP i dont want the new sensor to get messed up by a bad connector if thats possible?
mic
  #36
Old 03-16-2012, 12:50 PM
woodnthings
ICP Sensor for the best price! OEM!!!!!!
Riffraff Diesel: Motorcraft ICP Sensor 97-03
  #37
Old 05-07-2012, 10:23 PM
kevinkrueckemeier's Avatar
kevinkrueckemeier
kevinkrueckemeier is offline
Thanks Ken, my ICP had the "exact" ohm values as the bad one you described. Will buy a new one tomorrow and install.
MONAVIERONJON
06-17-2013 08:06 PM
Talyn
17
06-19-2011 02:06 PM
daughtersbronco
Bronco II
08-01-2010 07:57 PM
robjs111
01-06-2009 01:27 PM
ron's power stroke
10-06-2006 09:37 PM
Quick Reply: Injection Control Pressure Sensor ( ICP SENSOR ) Help
