Tire and rims help 48 f1
Guys, I have a question bout taking my rems that are on my F1 which I have tube tires.. Anyway I can use my old rims and put tubeless tires on the rims ? If so I can how do I go about doing so ?? if not what type of rims should I ask for and I know there 5lug rims. Whats the size rims should I buy ???
~Cody
~Cody
The stock 16" wheels have been used with modern tubeless tires. Several members have done it. You may have to apply a sealer to the inner rim bases to ensure no air leakage around the rivets, but that's about it. Others can speak to the tires they've used and had success with. My value system requires that I suggest you stay with reproduction 6.00 or 6.50 x 16" bias ply tires like were original to your truck. Places like Coker Tire or Universal Tire sell these. If you want to go with radials, keep in mind that your rims are 4.5" wide. This width rim would be spec'd for a 165 mm. or 175 mm. wide tire. Finding a 16" tire that is that narrow might be a task. Stu
The following users liked this post:
Danny in CO
17
12-26-2005 10:07 PM
58ford
06-06-2002 05:30 PM
