Transfer case engages, front driveline spins but no 4x4 - Ford Truck Enthusiasts Forums
Old 11-13-2011, 06:38 PM
stacked8769 stacked8769 is offline
stacked8769 is starting off with a positive reputation.
So i recently had a new transfer case put in my 87 6.9 and went hunting today had to stick it in 4 hi but all i had was rear wheel spin. You can hear the transfer case engage and the hubs were locked in but no front wheel spin. Any suggestions.
Old 11-13-2011, 07:20 PM
starmilt starmilt is offline
starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.starmilt has a very good reputation on FTE.
Unlock your hubs and put your transfer case in gear and then see if you can turn the front drive shaft by hand. If you can then your transfer case is not actually in gear or there is a problem with it. If it won't turn by hand then put your transfer case back in two wheel drive and make sure you can turn it, then you can lock your hubs in and isolate which one is bad if they are the problem.
Old 11-13-2011, 07:34 PM
everything is good there. i was told the rear end/ whole truck was regeard but i wonder if they just did the back and left the ring gear out of the front diff
Old 11-13-2011, 08:01 PM
Jack up both front wheels, with the transfer case in nuetral or in two wheel drive, turn one wheel by hand while the hubs are locked. The other tire should turn the opposite direction. If it doesn't turn the other side at all get someone to look while you turn and make sure the axles are turning at the ujoints,If only the axle that you are turning you may have a problem in the diff, most likely the spider gears. You can also just jack up one side and turn the wheel while someone looks at the axle, it will have some resistance, but should turn, then do the other side. this will eliminate the hubs.
Old 11-13-2011, 08:13 PM
alright ill try that
Old 11-13-2011, 08:24 PM
When you jack up one wheel at a time, it should also be turning your driveline when turning the wheel.
Old 11-14-2011, 09:34 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
No need to jack it up, just turn the ft driveshaft in 2wd. If the hubs are locked and ft diff is intact it wont turn. If it does turn, see which ft axle is turning... that hub isnt locked.
Another 4 wheel hub question OneTon350 1999 to 2016 Super Duty 1 08-06-2015 12:19 AM
1988 f150 front hubs lock, and wheels spin but i can stop with my hand jskeith47 1987 - 1996 F150 & Larger F-Series Trucks 7 06-30-2015 08:35 AM
need help please glogan 2004 - 2008 F150 0 02-19-2015 03:47 PM
Transfer case / Hubs / Diff / Vacuum confusion Enduroman 6.0L Power Stroke Diesel 17 12-06-2013 03:53 PM
Front hubs won't engage mattsautobody442 2004 - 2008 F150 1 03-03-2013 10:12 AM
Tags
2001, 4x4, case, driveline, driveshaft, engage, engages, explorer, front, put, spin, transfer, turning, wheels, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
