Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 11-13-2011, 05:36 PM
Biscayne Biscayne is offline
Garage is empty, add now
Biscayne is starting off with a positive reputation.
Intermittent transmission leak solved
I have had an intermittent transmission leak for a while now...it only leaked if truck sat on an incline (uphill) and was not driven for 2 days. On the second day it would dump a cup or two of transmission fluid down the driveway. I am posting the resolution and what it was for anyone else trying to pin point a trans leak.
70,000 miles, 2009 Expedition El 4wd/AWD. There is a "bulkhead" connector on the passenger side of the rear part of the transmission. On the second day after all ambient heat of driving had dissipated, while on an incline, the seal around the wire bundle entering the transmission would leak continuously. In order to repair....it requires dropping the pan, disconnecting the wires internally, removing the bulkhead connector and replacing the seal, oh and $450. They couldn't find the leak initially and had to put dye in it but several days later it was found. I am only posting this because you guys have been so helpful to me in other forums over the years I wanted to try and shorten y'alls troubleshooting in the future with the small piece of info I just paid for at the dealership.
__________________
2000 F-350 4WD CCSB, bone stock 7.3
Mama's 2009 Expedition EL 4WD
2002 F-250 4WD Extended Cab --sold
2001 F-250 Crew Cab 2WD -- sold
2001 F-250 4WD Extended Cab--Sold
  #2 (permalink)
Old 11-13-2011, 08:32 PM
Jay Jay is offline
Jay is starting off with a positive reputation.
How did you add fluid?
  #3 (permalink)
Old 11-14-2011, 08:48 PM
you and I cannot add fluid. There is not really a dipstick to even check level. There is supposedly a plug with a dipstick (accessible from underneath the truck) that you can check level and add by. I have not found it.
__________________
  #4 (permalink)
Old 12-05-2011, 02:07 PM
tbe2002 tbe2002 is offline
tbe2002 is starting off with a positive reputation.
Just had this same problem on my 08 limited with 80,000 miles. There is a dipstick on the pass side of the trans up by the cat on that side. There is a bolt to take off then a little plastic dipstick. Just make sure the truck is running or it will over flow, Oh and watch your hands u know since the cat is right there and the truck needs to be running to check the fluid.
Yeah had that bulk head connector replaced on the back of the trans to a tune of 350 including a filter and flush.
  #5 (permalink)
Old 01-02-2012, 06:25 PM
brian09exp brian09exp is offline
brian09exp is starting off with a positive reputation.
just replaced the bulk head connector on my 09 exp
Hi,
I checked the leak and for sure it was in the bulk head connector so I bought the part at the ford dealer ($26+), dropped the pan and replaced it myself....just make sure the replacement part has the black o-rings on and not the original red ones. I'll post if there are any problems, but it was a lot tighter fit than the old one so it should have fixed it. The part number is in the tsb area under f-150 '10
  #6 (permalink)
Old 01-14-2013, 02:31 PM
fortdavisgirl fortdavisgirl is offline
fortdavisgirl is starting off with a positive reputation.
Transmission Leak solved
Has anyone been successful in getting Ford to admit this bulkhead connector defect is a known problem, and get the repair done for free?
Tags
2009, bulk, bulkhead, connector, expedition, explorer, f150, ford, head, intermittent, leak, leaking, replace, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
