4x4 vacuum hoses to front hub - Ford Truck Enthusiasts Forums
Old 11-13-2011, 04:30 PM
bebeard's Avatar
bebeard bebeard is offline
bebeard is starting off with a positive reputation.
hi all...
i'm trying to find the right hose that I need to check and or replace ?
2004 250
thx
Old 11-13-2011, 05:14 PM
Maxium4x4's Avatar
Maxium4x4 Maxium4x4 is online now
Maxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputationMaxium4x4 has a superb reputation
Here is a single post to your question. Can you give a little more information?
Old 11-13-2011, 07:18 PM
bebeard's Avatar
4x4 vacuum hoses...
My 4x4 on the fly won't engage and I was told it could be the vacuum hoses and I was going to check them..
thanks,
Old 11-13-2011, 07:25 PM
Maxium4x4's Avatar
I do not have ESOF but past history on the subject it is probably the hub seals leaking. Do you notice the pump running constantly?
Old 11-13-2011, 08:24 PM
bebeard's Avatar
4x4 vacuum hoses...
hello... No I haven't noticed anything on the pump... but i'm not sure where the pump is...
Old 11-13-2011, 08:27 PM
gatormccluskey's Avatar
gatormccluskey gatormccluskey is offline
gatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to behold
Passenger side under the hood. Behind the battery. The vac pump has three small tubes going to it. The valve next to the pump is what works the 4x4
Old 11-13-2011, 10:58 PM
bebeard's Avatar
4x4 vacuum hoses...
thanks... I will take a look and listen first thing tomorrow..
Brook
Old 11-15-2011, 09:32 AM
bebeard's Avatar
good day,
I found the pump and no its not running all the time.
Is there something else I need to be looking for? its there a way to test the pump?
thanks,
Brook
Old 11-15-2011, 06:34 PM
Maxium4x4's Avatar
The pump does not run continuously if everything works and no leaks. You would notice your defrost to floor not working if you had no vacuum. I still vote for the front hubs. Have you manually locked the hubs to make sure the transfer case is engaging?
Old 11-15-2011, 07:36 PM
bebeard's Avatar
Yes, I have been able to manually lock the front hubs.
So what is your recommendation at this point?
Brook
Old 11-15-2011, 07:38 PM
Maxium4x4's Avatar
Check the seals on your front hubs or lock them manually if needed.
Old 11-15-2011, 07:43 PM
bebeard's Avatar
great.. thanks...
Will start looking into it.. or might just manually lock them.. :_)
will see
Old 11-15-2011, 08:01 PM
bebeard's Avatar
ARe the front hub seals something that the average joe can change?
or is it something that I need to have done?
Thanks,
BRook
Any youtube videos?
Old 11-22-2011, 09:55 AM
Steve_250's Avatar
Steve_250 Steve_250 is offline
Steve_250 is gaining momentum as a positive member of FTE.Steve_250 is gaining momentum as a positive member of FTE.
Heater Hose Under Intake 04mudslinger 1997 - 2003 F150 4 03-17-2016 08:45 AM
CCV hose bigb56 1999 - 2003 7.3L Power Stroke Diesel 1 09-29-2014 10:16 PM
Radiator water hose leak Wrench Bender 117 1999 to 2016 Super Duty 1 11-10-2013 12:29 PM
4x4 hose diagram? 02 Super Duty Guy 1999 to 2016 Super Duty 2 08-12-2013 02:18 PM
Heater hose sizing on 93 Ranger 3.0? fatherdoug 3.0L V6 1 01-27-2004 08:06 AM
Tags
2002, 4x4, 73l, diesal, f150, f250, ford, front, hose, hoses, hub, lines, pump, truck, tubing, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
