Distributer wiring question
Old 04-12-2003, 04:51 PM
labrouse's Avatar
labrouse
labrouse is offline
Question Distributer wiring question
I am putting in a 1986 5.0 302 into my 1960 F100. I have a quick question that I hope someone can help me with. There are three wires comming off of the distributer a purple, a black, and orange. I need some help on exactly where these wires connect to on my truck. Thanks for the help
Old 04-12-2003, 09:24 PM
Gear Up's Avatar
Gear Up
Gear Up is offline
Are you planning to use the ignition harness that the 302 came out of or are you going to use the wiring that came with the truck? If you plan on using the high energy ignition system from the donor vehicle you need to transfer the ignition system and the ECM to make the engine run properly. Otherwise if you are using the original truck harness you will have to use a Distributor that is compatible with the old system. You have two different voltages used; 12 volts when starting the engine and around 8 volts when the engine is running. The old point system required lower voltage when running so there is a ballast resistor either in the harness such as a nichrome wire or an actual ceramic cased resistor to drop voltage. I am not well enough versed with the old Fords to tell you where to look. Personal preference would be to go with the newer system because it is more reliable. I remember having to repace points on my old Fords on a regular basis. The HEI is much more convenient.
Good luck.
Gear Up
Old 04-12-2003, 10:46 PM
labrouse's Avatar
labrouse
labrouse is offline
I have the ECM that came out of the mustang. I have gotten a wire diagram that shows that the orange, purple, and black wire from the dist. go to the ECM. And then off of the ECM is a red wire that goes to the starter relay (+)? and a white wire that goes to the ign wire? and a green wire that goes to the ign coil? I guess that I am reading this right. The electrical system is a Dura SparkII 1981-85. I guess that what I am looking for is to not burn any thing up in the process. Thank for the help.
Old 04-13-2003, 08:57 PM
Purple55's Avatar
Purple55
Purple55 is offline
Labrouse,
I've got the same set up on my '55 with 460.The only difference is,I've got the white wire going to the solenoid and the red going to ignition.
Greg
Old 04-13-2003, 09:22 PM
Purple55's Avatar
Purple55
Purple55 is offline
Labrouse,
Greg
Old 04-14-2003, 10:47 AM
labrouse's Avatar
labrouse
labrouse is offline
Thanks Purple55,
Where do you have the green going? Also, "silinoid", is this the starter relay or coil?
Old 04-14-2003, 08:01 PM
Purple55's Avatar
Purple55
Purple55 is offline
Green goes to coil and the solenoid is the starter relay.
Old 04-14-2003, 09:58 PM
labrouse's Avatar
labrouse
labrouse is offline
Thanks Purple55. I really would like to thank you for your help and time that you have taken to give guys like myself the assistance that we might lack. Again thank you.
