You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am new to the forum. I have a 1960 Ford F-100 with a 390 and C6 in it. I am interested in putting power brakes or at a minimum putting a dual master cylinder on it. Anyone have suggestion for swapping from a later model truck or buying a kit from manufacter? Thanks.
On mine I used a hydra-vac booster off a '59 f600. Works great and stops on a dime. I've been told that a booster/mastercylinder from a mid 70's Ford truck bolts right in but I've never actually compared them in person.
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
Excellent placement on the Hydra-Vac booster, not stock mounting point of course, but at least it's not in the way like the other up-grades that I've seen.
Quote:
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica) My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
Thank for the info. That is really a conversation piece I bet when you lift the hood.
I bought a dual resevoir master cylinder for my 58F100 from Engineered Components 860-872-7046 and it works fine. As I recall its a late model Lincoln dual resevoir master cylinder and a seperate adapter(conversion) that allows one to bolt it to your firewall etc and use all your existing pedals etc.
Its a manual not power master cylinder etc. But I believe they offer power too.
Don't know if they still offer it, but it works fine for me. My only thought is that I think if I were doing it again--today etc-I'd go with power discs. I think the four wheels drums--for me--and high speed driving are not quite as good as I'd like and I might make an improvement some day.
They work as expected its just that my 58 goes pretty fast--some times-and it takes more time to slow it down that I really like.
My 48F1 with factory drums and a much smaller motor stops really good--but its lighter and not so fast. The faster/heavier truck needs more stopping power.
By the way, I like Ibuzzard's suggestion too. Just trying to add more options that's all.
