6.0 white smoke loss of power rough idle need help
Old 11-13-2011, 03:29 PM
dwood3311's Avatar
dwood3311
dwood3311 is offline
i have an 05 f250 started running rough when the motor is cold starts up ok idles rough spits a little white smoke i let it warm up for bout 15 minutes then take off it blows white smoke and has no power for 2 or 3 miles then everything clears up and it runs fine can anyone help me out here
Old 11-13-2011, 03:40 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
Your other thread got moved to this forum check it out
Old 11-13-2011, 07:03 PM
ddeguire's Avatar
ddeguire
ddeguire is offline
I have the exact same issue on my 05 Excursion. I had local dealer check the FICM and they said it was up to date and there were engine codes being thrown.
Old 11-13-2011, 07:41 PM
dwood3311's Avatar
dwood3311
did u find out what is going on i am taking mine in wed half afraid to drive cause i dont want to make things worse in case there is internal issues
Old 11-13-2011, 07:58 PM
ddeguire's Avatar
ddeguire
ddeguire is offline
No I didn't. I've been driving it anyway. It's a third car for me so I don't drive it much. Runs fine when warm. I'm going to take it back to the dealer and leave it overnight so the tech can see how it runs cold and then diagnose it from there.
Old 11-13-2011, 08:03 PM
gatormccluskey's Avatar
gatormccluskey
gatormccluskey is offline
Have yall did the EGR delete ? Pull the EGR sensor and see if it is gumed up. If it is, clean with spray brake cleaner. See if it runs any better. Then let us know
Old 11-13-2011, 08:12 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
You shouldn't use brake cleaner, Carb cleaner in the intake system.
Old 11-13-2011, 08:14 PM
gatormccluskey
Brake cleaner will clean it better. The gum is hard to get of. Let it dry before you put it back on. Will dry in about ten sec.
Old 11-13-2011, 08:29 PM
ddeguire's Avatar
ddeguire
ddeguire is offline
Haven't done that. I'll have to do a search to find the egr. Easy to remove and replace?
Old 11-13-2011, 08:32 PM
gatormccluskey
It is on top of the engine, close to the front. It will be the first sensor you see. About three inches tall and about two inches round. It has a plug in the top. It takes about five min to get out.
Old 11-13-2011, 08:36 PM
ddeguire's Avatar
ddeguire
ddeguire is offline
Now that's my kind of work! If it gets much more than that then I'm in trouble! I race cars for fun and I'm a joke in the garage. Change pads and rotors and that's about it. Anything more technical than that and I have to make a call for help.
Old 11-13-2011, 08:39 PM
gatormccluskey
And I dont do the racing. LOL Let me know how it acts when you clean the sensor. We will check futher if we have to.
Old 11-13-2011, 10:10 PM
ddeguire's Avatar
ddeguire
ddeguire is offline
Will do and thanks.
Old 11-14-2011, 06:44 AM
dwood3311's Avatar
dwood3311
dont have the egr delete that i no of only had the truck a couple months just bought it it has 144000 miles wasnt looking to spend big money getting it fixed already but injectors egr delete or ficm all seem like they are going to be expensive
Old 11-14-2011, 06:58 AM
bismic's Avatar
bismic
bismic is online now
Received 2,490 Likes on 1,727 Posts
The reason Ford says "No Brake Cleaner" is that brake cleaner fluid is not compatible with the EGR valve seals. Even if you are careful and don't get it in the weep holes, the solvent can wick up the shaft and potentially soften the shaft seals. Carb cleaner works well enough and it is adviseable to use it over brake cleaner.
Quick Reply: 6.0 white smoke loss of power rough idle need help
