6.0 white smoke loss of power rough idle need help - Ford Truck Enthusiasts Forums
Old 11-13-2011, 04:29 PM
dwood3311 dwood3311 is offline
dwood3311 is starting off with a positive reputation.
i have an 05 f250 started running rough when the motor is cold starts up ok idles rough spits a little white smoke i let it warm up for bout 15 minutes then take off it blows white smoke and has no power for 2 or 3 miles then everything clears up and it runs fine can anyone help me out here
Old 11-13-2011, 04:40 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Your other thread got moved to this forum check it out
Old 11-13-2011, 08:03 PM
ddeguire ddeguire is offline
ddeguire is starting off with a positive reputation.
I have the exact same issue on my 05 Excursion. I had local dealer check the FICM and they said it was up to date and there were engine codes being thrown.
Old 11-13-2011, 08:41 PM
did u find out what is going on i am taking mine in wed half afraid to drive cause i dont want to make things worse in case there is internal issues
Old 11-13-2011, 08:58 PM
No I didn't. I've been driving it anyway. It's a third car for me so I don't drive it much. Runs fine when warm. I'm going to take it back to the dealer and leave it overnight so the tech can see how it runs cold and then diagnose it from there.
Old 11-13-2011, 09:03 PM
gatormccluskey's Avatar
gatormccluskey gatormccluskey is offline
gatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to beholdgatormccluskey is a splendid one to behold
Have yall did the EGR delete ? Pull the EGR sensor and see if it is gumed up. If it is, clean with spray brake cleaner. See if it runs any better. Then let us know
Old 11-13-2011, 09:12 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is online now
I'm hitting easy street
amdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputationamdriven2liv has a superb reputation
Quote:
You shouldn't use brake cleaner, Carb cleaner in the intake system.
Old 11-13-2011, 09:14 PM
Brake cleaner will clean it better. The gum is hard to get of. Let it dry before you put it back on. Will dry in about ten sec.
Old 11-13-2011, 09:29 PM
Haven't done that. I'll have to do a search to find the egr. Easy to remove and replace?
Old 11-13-2011, 09:32 PM
It is on top of the engine, close to the front. It will be the first sensor you see. About three inches tall and about two inches round. It has a plug in the top. It takes about five min to get out.
Old 11-13-2011, 09:36 PM
Now that's my kind of work! If it gets much more than that then I'm in trouble! I race cars for fun and I'm a joke in the garage. Change pads and rotors and that's about it. Anything more technical than that and I have to make a call for help.
Old 11-13-2011, 09:39 PM
And I dont do the racing. LOL Let me know how it acts when you clean the sensor. We will check futher if we have to.
Old 11-13-2011, 11:10 PM
Will do and thanks.
Old 11-14-2011, 07:44 AM
dont have the egr delete that i no of only had the truck a couple months just bought it it has 144000 miles wasnt looking to spend big money getting it fixed already but injectors egr delete or ficm all seem like they are going to be expensive
Old 11-14-2011, 07:58 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
The reason Ford says "No Brake Cleaner" is that brake cleaner fluid is not compatible with the EGR valve seals. Even if you are careful and don't get it in the weep holes, the solvent can wick up the shaft and potentially soften the shaft seals. Carb cleaner works well enough and it is adviseable to use it over brake cleaner.
Rough idle and blue/white smoke t-bone31 6.0L Power Stroke Diesel 10 03-14-2016 08:36 AM
Rough idle at start-up SC_Dave 1999 - 2003 7.3L Power Stroke Diesel 36 11-15-2014 08:19 AM
rough 302 with white smoke oldbeater 1987 - 1996 F150 & Larger F-Series Trucks 4 07-30-2011 12:23 AM
White smoke, rough idle, no power 429poweredf350 6.0L Power Stroke Diesel 8 12-07-2010 10:39 PM
hard start/rough and white smoke when cold HELP!! powerstroke956 6.0L Power Stroke Diesel 13 10-28-2009 09:42 PM
Tags
05, 60, 60l, 64, diesel, f250, ford, idle, litre, loss, power, rough, smoke, smokes, warm, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
