Pics of coolant & coolant filter after 1k
These pictures were taken after 100+ flushes and head stud, coolant and egr cooler replacement. At which time my ect/eot were only 3-5* then started creeping up to 10-15*. so decided to do a backflush of entire system.This is the initial drain of coolant[/IMG][/IMG]This is back flushing the oil cooler[/IMG]These are pics of coolant filter and the debris that came out of it. [/IMG][/IMG][/IMG]
This is the initial drain.[IMG]<a href="http://s1105.photobucket.com/albums/h342/snorindad/?action=view&current=IMGP4255.jpg" target="_blank"><img src="http://i1105.photobucket.com/albums/h342/snorindad/IMGP4255.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1105.photobucket.com/albums/h342/snorindad/?action=view&current=IMGP4251.jpg" target="_blank"><img src="http://i1105.photobucket.com/albums/h342/snorindad/IMGP4251.jpg" border="0" alt="Photobucket"></a>[/IMG]
This is the initial flush of oil cooler[IMG]<a href="http://s1105.photobucket.com/albums/h342/snorindad/?action=view&current=IMGP4246.jpg" target="_blank"><img src="http://i1105.photobucket.com/albums/h342/snorindad/IMGP4246.jpg" border="0" alt="Photobucket"></a>[/IMG]
This is the coolant filter and the debris that was in it
[IMG]
[IMG]
[/IMG][/IMG][IMG]<a href="http://s1105.photobucket.com/albums/h342/snorindad/?action=view&current=IMGP4256.jpg" target="_blank"><img src="http://i1105.photobucket.com/albums/h342/snorindad/IMGP4256.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1105.photobucket.com/albums/h342/snorindad/?action=view&current=IMGP4247.jpg" target="_blank"><img src="http://i1105.photobucket.com/albums/h342/snorindad/IMGP4247.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]<a href="http://s1105.photobucket.com/albums/h342/snorindad/?action=view&current=IMGP4248.jpg" target="_blank"><img src="http://i1105.photobucket.com/albums/h342/snorindad/IMGP4248.jpg" border="0" alt="Photobucket"></a>[/IMG]
[IMG]
[IMG]
Yep I wanted to make sure I got it as clean as I could but as you can see I am still getting s#@t out of it. If I had it to do over I don't think I would do the chemical flushes I would just flush with distilled water only. The only thing that made it easier was installing fumoto valves for the block drain plugs. I will continue to flush every 1k or so until I have clean coolant come out.
Here is a link to nylyons' "reverse flushing" technique. http://home.comcast.net/~lyon.family...ush%20v1-0.pdf
I am currently do this as we speak. I would like to get my temps back down to the 3-5 that they were after top end work was done. but I am afraid I will have to install another oil cooler to get that result again.
What is the make and number of the spinon filter? Trying to locate waterfilters in Sweden... Tia
I am using Baldwin B5134. I bought a kit from defuser and it came with 3 filters.
Code:
What type of coolant are you using? BTW my 05 has only seen distilled water coolant flushs since I only get just a few sand particles out when I first open the radiater drain plug.
look towards the radiator for the source of contamination.try flushing only the radiator in a clean bucket a couple times,i think youll be surprised at what you get out of it.
I had the radiator rodded (it was 30% plugged) last August when I did all the work to this also installed new oil cooler, egr cooler, heater core, water pump, and replaced all hoses. I also did about 100 fluses with restor and restor plus before starting the project and could never get 100% clean water (hose and distilled) out. 90% of the sand I am getting out of this engine is coming out of the block drain plugs.
How many miles do you have on your truck? I know Ford recommends doing the initail flush for the P/S's at 105k.
Get's me concerned after only 60k on mine.
High Binder
05-25-2012 10:49 PM
