Ever thought of the ultimate 300?
I have been for a long time. Taking clues from newer rigs, and old school simplicity, here's my idea:
-Standard 300 build with all stock internals, except hyper pistons at about 8.2-8.5:1. Maybe head & main studs, & ARP rod bolts.
-Late model EFI 4.9 intake with a little bigger & better injectors.
-EFI controller? Not sure, but Megasquirt seems like it would have to do. Run it for Mass air, not speed density. That, or custom reflashed Ford computer.
-Airesearch T04 turbo to bring some top end & towing fun to it.
The ultimate 300?
Bore it 0.030'' over
block decked to 0 height
Offset ground crankshaft to stroke it
Line bore the main crank bearings
Balanced
Custom grind cam (HOT HOT HOT)
Roller lifters and rockers
Screw in studs and stiffer valve springs
LS1 heads welded together and custom intake and exhaust
4 barrel 600 cfm holley with an Eaton supercharger wth the appropriate compression to run it
Massive head porting and opened up to larger valves
9'' rear with 3.55 gears and a C6 transmission
... All of this sitting in a 64' or 65' Falcon or a 66 Fairlane.
Just my opinion.
Your motor sounds good too though.
Balanced
Just my opinion.
For pure power though, flashman's build has topped the charts.
meangreen92
04-11-2018 08:00 AM
cowboy.2010
03-02-2013 12:31 AM
