How to change heater core '92 F250? - Ford Truck Enthusiasts Forums
Old 11-13-2011, 11:24 AM
boothtec boothtec is offline
boothtec is starting off with a positive reputation.
How do you access the heater core on a 1992 F250? Do you have to remove the AC evap coil?
Old 11-13-2011, 11:32 AM
86F150302's Avatar
86F150302 86F150302 is offline
86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.86F150302 has a very good reputation on FTE.
Behind glovebox. I've done 3 so far. Nothing to them really.
Old 11-13-2011, 11:50 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Did mine recently, IIRC, I had to remove the glove box then it was pretty straightforward. AC didnt interfere, just unbolt the panel in the heater box and slide the old one out. I changed my coolant and added sca's when I did mine also.
heater core rkmason Large Truck 2 12-09-2014 09:17 PM
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 02:05 PM
heater core cws10190 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-17-2012 06:11 PM
1985 f250 heater core f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-19-2011 07:55 AM
Heater Core NoHeart2 1999 to 2016 Super Duty 3 10-28-2009 01:13 PM
Tags
1992, 1992f250heatercore, 1994, 1997, 250, 73, 92, 94, change, changing, core, f250, ford, heater, replace
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
