99 navigator wont start. theft light.
Wife went to start the car this morning. Would not fire. Engine cranks. Theft light goes off after three seconds with key in the ignition. Take the key out and the theft light blinks every two seconds. Tried multiple keys. None work. Made sure only one key on key chain. Keyless entry still works. Fobs still work. Tried disconnecting battery. Everything I am.reading says I will have to tow it to a dealer. Cant pull codes. Any ideas?
99 navigator 4x4 5.4 sohc
Thanks
Nick
Thanks
Nick
If your '98-'00 Expi/Navi has the Ford System 3 (or 4) Security System the following applies:
It has a small red light (Valet Button) below the steering wheel, sort of between your knees. Look directly behind that little red light on it's wire loom that goes up under the dash, there is a very small Micro 'Emergency Override Button' about 3" behind the Valet Button on the loom. You'll need a flashlight.
When you find it, insert the key and turn on the ignition so all the dash lights are on - then push the Override Button, the Security System should now be disabled and the car should start.
You may have to hold down the Override Button while cranking the engine over.
You can re-set this entire system too.
To re-initialize Ford System 3 (or 4) Alarm System:
Disconnect the battery.
Wait 2 minutes for the module to lose all traces of voltage.
Turn the ignition key to the RUN position.
Reconnect the battery.
Shut the key OFF and press LOCK on the drivers door switch.
Done.
The system should work correctly. If it doesn't then a part of the system has failed.
Done.
If you don't have the extra system Boat Tug described (never have seen one...), you're left to check the basics like air, spark, and fuel.
98 theft light issues.please help
hiim having issues.please help im going to make short. i try abrithing you see online nothing work.i change the key transponder no luck change the theft module no luck hcang the ecc module no luck change the stupid computer no luck reprogram the keys like 3 times all was done.still same problem.can anyone help.what im missing.all the parts ae working condition and all the numbers match.
cardc26
09-18-2012 05:04 PM
Peter Greenlund
08-31-2004 02:13 PM
